Clicking noise after using 4WD
Old Jun 6, 2011 | 08:34 AM
Abester89's Avatar
Abester89
Yesterday i used the 4WD on my 1995 Ford F-350 7.3 powerstroke 5-speed diesel, right after i took it out of 4WD i heard a strange clicking noise, when in gear and when it just sits there and idles. but when i drive it gets louder and worse. Anyone know what this could be?
Old Jun 6, 2011 | 09:08 PM
Jus2shy's Avatar
Jus2shy
My want to try the Super Duty forum section, this is for the 2009+ F150's.
Old Jun 7, 2011 | 07:21 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the "1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucks" forum
WELCOME to FTE!
Old Jun 7, 2011 | 07:54 AM
donnor's Avatar
donnor
Strange sounds usually = $...
Noisy in gear, clutch pedal depressed? noisy in neutral clutch in or out? Throw out bearing? Clutch fork/fingers? Manual or auto hubs? More info, please. While not a great idea to get under truck while running (at least not without help and/or properly securing it), listening from below may give some idea of the precise area from which the sound is emanating. It might also be as simple as a stick or woody-stalked weed jammed in somewhere.
dn.
Old Jun 7, 2011 | 08:40 AM
Abester89's Avatar
Abester89
While its sitting there idling in neutral, when I push the clutch in and also when in gear it makes the noise. It has manual locking hubs. While its in neutral if I put my hand on the 4WD stick I can feel the clicking noise. So my guess is that its coming from the transfer case. Could low fluid in the transfer case cause this? It almost seems like it never fully disengaged out of 4WD.
Old Jun 7, 2011 | 09:46 AM
Lazy K's Avatar
Lazy K
If it still makes the noise with the clutch pedal depressed and a gear selected then it is nothing in the transmission, transfer case or 4x4 system.
Could be a throwout bearing, clutch pressure plate or dual mass flywheel. Could also be a loose dust shield or loose starter motor.
jeepfix
Aug 22, 2015 09:18 AM
90turbo1
Jan 4, 2015 01:52 PM
Pigman54
Oct 31, 2014 12:37 PM
hiroller
Escape & Escape Hybrid
Aug 3, 2014 11:34 AM
mike bell
2004 - 2008 F150
Mar 6, 2014 07:35 AM
