2x4 to 4x4 conversion
Old Mar 25, 2003 | 06:31 PM
comet's Avatar
comet
I have found a donor rolling 4x4 chassis for my '71 F250 2wd. Before I buy it, what are some things I should look for? Here's what I know. D44/D60 axles, AT (C6, I guess, was anything else offered in early 70's?), t-case in good condition. I understand that the autos did not use the NP205 t-case, is this correct? Frame is supposedly in good condition. No power steering, but I think that's the way they all came, right? Can I use my 2wd power steering box? I don't think so, but wanted to ask.
He does not know the exact year of the frame, but said it is early 70's. Are there any concerns about the years? I mean will a '73-7? frame work without problems?
Any insight would be appreaciated.
Thanks
Old Mar 26, 2003 | 07:06 PM
rebocardo's Avatar
rebocardo
> D44/D60 axles
I would hazard a guess this is probably a F250 with that set up.
> came, right?
For 68-72 I think
F-100 = no power steering
F-250 = power assist
Then 73-79 = power steering
Ideally, with a min. of hassle, a 68-72 frame would be good. But, with a good frame and matching drivetrain for cheap money it would not matter much to me at least. You can always weld up <a href="http://www.motorhaven.com/">cab mount</a>s. Though I think 68-72 F-250s had special <a href="http://www.motorhaven.com/">cab mount</a> bushings.
No, but, to add power steering and disc brakes you are much better off with this set-up, especially if you are getting the axles and drivetrain.
Old Mar 26, 2003 | 09:36 PM
comet's Avatar
comet
Thanks, rebocardo. Good info. I ran the vin, but it was very hard to read, so I am not sure I got it right. It says its a 1975 f250, but what I am curious about is which digits in the vin indicate year? If they are the digits in question, then maybe it's something else. If they are not, then it's a 1975.
It has closed knuckles on the d44 and had power assist, but that was parted out. When did they stop the closed knuckles on f250?
Old Mar 28, 2003 | 08:12 AM
fatdaddy's Avatar
fatdaddy
closed knuckles were phased out in 76 and i think maybe some late 76's may have rece'd the open knuckle type axles. power assist was converted over to regular ps in mid year-77.....fd
Old Mar 28, 2003 | 01:37 PM
comet's Avatar
comet
Thanks Fatdaddy. So are the closed knuckles any good? I am not going to be hard core wheeling, just forest service roads and snow. Can it be converted to open knuckle? I plan to upgrade to front disc anyway, so if I could make a change I will.
