I need help
Old Jun 5, 2011 | 07:59 AM
Warderkous's Avatar
Warderkous
I need help
2000 f250 7.3 stock engine (no mods) will not drive park and neutral are the only to gears that work rpms change when trying to go in reverse and drive but nothing else happens
Old Jun 5, 2011 | 08:16 AM
bfife's Avatar
bfife
still plays with trucks
alittle more info please. 2WD or 4WD. we've had some issues with transfer cases going out lately. does park work? How is your fluid level? how does the fluid look and smell?
any signs of leakage?
Barney
Old Jun 5, 2011 | 09:04 AM
Warderkous's Avatar
Warderkous
park does work 4wd fluid looks and smells good
Old Jun 5, 2011 | 09:05 AM
Warderkous's Avatar
Warderkous
prior to yesterday no signs of any problems i rac a code reader and the is a P0603 code
Old Jun 5, 2011 | 09:08 AM
Warderkous's Avatar
Warderkous
I was on my way back from autozone with a new water pump that i was getting ready to install
Old Jun 5, 2011 | 09:13 AM
Kwikkordead's Avatar
Kwikkordead
Sounds like your transmission lost hydraulic pressure for some reason.
Old Jun 5, 2011 | 09:19 AM
Warderkous's Avatar
Warderkous
what is the fix for that
Old Jun 5, 2011 | 09:21 AM
clux's Avatar
clux
Have you checked the transmission oil level with the engine running?
Old Jun 5, 2011 | 09:24 AM
Warderkous's Avatar
Warderkous
added two quarts yesterday
Old Jun 5, 2011 | 11:11 AM
nlemerise's Avatar
nlemerise
I assume that the transfer case has been checked to actually be in gear? Someone recently wrote about your problem and it turned out their transfer case was in neutral (yeah, it will grind going into park when t-case is in neutral...maybe OP didn't mention it thinking it wasn't related).
Old Jun 5, 2011 | 11:51 AM
Warderkous's Avatar
Warderkous
how do you take it out of neutral
Old Jun 5, 2011 | 12:13 PM
nlemerise's Avatar
nlemerise
Ahhh, the ambiguity of the written word . Do you have the auto-shift transfer case or do you have the floor mounted manual transfer case?
Old Jun 5, 2011 | 12:15 PM
Warderkous's Avatar
Warderkous
it is an auto matic i think it is the one on the dash below the stereo
Old Jun 5, 2011 | 12:26 PM
nlemerise's Avatar
nlemerise
Well, I can't help you because I have never owned an auto-shift transfer case...OK you 4x4 geniuses, does the auto-shift transfer case have any way to be set into a NEUTRAL position...I see on the dial (in the manual) that the control **** has no neutral position.
Old Jun 5, 2011 | 12:54 PM
clux's Avatar
clux
I don't think there's any way to put them in neutral.
