help with engine swap
Old Jun 4, 2011 | 01:22 PM
DaltonCarter's Avatar
DaltonCarter
Exclamation help with engine swap
i have a 1974 ford f-250 and recently blew a head gasket. we bought a 1991 fuel injected motor and when switching the intake manifold over we found that no gaskets would work with the manifold off the carburetor motor and the heads on the fuel injected motor. if anyone knows a way to fix this or if a company makes a manifold that would work please let me know. thank you
Old Jun 4, 2011 | 01:46 PM
Boba Fett's Avatar
Boba Fett
Are these engines 351Ws?
Old Jun 4, 2011 | 02:29 PM
DaltonCarter
they are 460's
Old Jun 4, 2011 | 02:47 PM
evam350's Avatar
evam350
You will need to use the carb heads or else figure out a way to mount your carb on the fuel injected intake and you would have to leave the injectors in to plug the holes.
Here's an adapter to mount a carb onto the efi manifold, it also has brass plugs for the fuel injector holes.
http://www.pricemotorsport.com/html/body_cs-460efi.html
Old Jun 4, 2011 | 04:11 PM
DaltonCarter
okay thank you for your help.
