Pulling a cab, Need some advice
Old Jun 4, 2011 | 11:01 AM
JimG1098's Avatar
JimG1098
Hey gang,
I am trying to pull my cab off a 54 F750. Will the steering box, fit through the brake-clutch pedal opening on the floor board.
I have to pull my oil filter out to get the steering box away from the frame, then I am wondering if i can retract the whole unit back into the cab
Thanks all
JimG 1098
Old Jun 4, 2011 | 12:19 PM
jaye's Avatar
jaye
When I installed one in my 55 years ago when I had the original box it did fit through the opening. I know the cabs are the same I'm not sure your truck box is bigger than the F-100.
Old Jun 4, 2011 | 12:34 PM
56panelford's Avatar
56panelford
You'll be good to go through the floor opening.
Old Jun 5, 2011 | 06:20 AM
JimG1098's Avatar
JimG1098
Many thanks.
Went to work on it yesterday. Pulled pittman arm and box loose. Could not get enough clearence to get the steering box out fron under the frame rail. Not sure what my nest approach is. Thanks for the assist.
JimG 1098
