Sponsored by: Auxito
Gas fumes
Old Mar 25, 2003 | 04:51 PM
mbowker64's Avatar
mbowker64
Question Gas fumes
I have another question. When I fill up the gas tank in warmer weather(above freezing), the cab fill with gas fumes if I don't turn the heater/ac switch to off. The fumes dissipate after a few minutes and don't come back until the next fill up. Any ideas?
1999 F150 4x4.
Old Mar 25, 2003 | 08:06 PM
Racerguy's Avatar
Racerguy
Gas fumes
It would appear that you have a tank vent problem but if you do the check engine light should come on indicating that.
You might be able to take a light and a mirror and check the top of the gas tank for signs of a leak. You would probably see a stain. If I was checking into this at work I'd look at the canister vent hoses from the tank to the engine, probably in particular behind the L/F wheel where the hoses connects to the pipe there. If that looked ok I'd hook up the smoke machine and see where smoke comes out. Seeing that a smoke machine isn't something that most people have laying around, you might want to take your truck to the dealer and get it checked that way.
Maybe someone else will have some more ideas
Old Mar 26, 2003 | 05:20 PM
AegisSailor's Avatar
AegisSailor
Gas fumes
I know this isn't helpful, but the first thing that came to my mind when I read your post is why is your engine running when your pumping gas?
Old Mar 27, 2003 | 04:22 PM
mbowker64's Avatar
mbowker64
Gas fumes
The engine is off with doors and windows shut. If I leave the heater control anywhere but off, the cab fills with fumes. I can air it out, park it with everything shut and the heater control where ever and its fine. The fumes only come in when filling the tank and once gone, don't come back until the next fill up.
arrowheadfred
16
Apr 25, 2011 08:04 AM
DNJSDAD
Feb 13, 2009 05:35 PM
SpeedJunky
Jul 24, 2007 09:25 PM
GreatNorthWoods
13
May 29, 2007 08:57 AM
JPontius
Dec 2, 2004 07:33 PM
