Electrical Problem
Old Jun 3, 2011 | 08:28 PM
Diesel 724's Avatar
Diesel 724
Electrical Problem
Sorry its kind of a repost but i have more info and really need the help. My #8 under the hood fuse keeps blowing immedietly. It controls my running lights, tail lights, and dash illumination. Im at a loss, i dont know where to look or what to do. Can anyone help me?
Old Jun 3, 2011 | 08:39 PM
tdpower's Avatar
tdpower
Sounds like a short to ground somewhere. I would start by checking out the wiring going to your lights and plug.
Old Jun 3, 2011 | 08:54 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Do you have a electric brake controller hooked up in your truck?
Old Jun 3, 2011 | 09:21 PM
Diesel 724's Avatar
Diesel 724
Nope no brake controller.
Old Jun 3, 2011 | 09:55 PM
Diesel 724's Avatar
Diesel 724
It only blows when i turn the light switch on, so i know to look after the switch in the circuit right?
Old Jun 3, 2011 | 10:37 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Yes that would be correct. IIRC the wire harness that gos to the tail lights runs down the drivers side of the frame and there is a plug back there near the tail lights under the truck. find this plug and unplug it that will isolate the tail lights. some one correct me if I'm wrong.
Old Jun 3, 2011 | 11:21 PM
clintbonnie's Avatar
clintbonnie
Make sure your light housings don't have rain water trapped inside.. this will cause a short.
Old Jun 3, 2011 | 11:44 PM
Sheldon Plankton's Avatar
Sheldon Plankton
Originally Posted by Deluxe06
....find this plug and unplug it that will isolate the tail lights. some one correct me if I'm wrong.
You're correct. I've pulled my bed a couple of times for various projects. There will be a big plug between the spare tire and the bumper. Three plugs actually, if you have the tow package and a dually with fender lights. If the OP disconnects the tail lights and the fuse doesn't blow, he'll have isolated the problem.
Old Jun 4, 2011 | 11:21 AM
Diesel 724's Avatar
Diesel 724
Thanks for the help ill give it a look today and post back to let you know what i find out.
Old Jun 4, 2011 | 12:07 PM
Diesel 724's Avatar
Diesel 724
Heres another stupid question, If my brake lights still work, wouldnt that mean the problem is not located in the tail light section? Just a guess?
Old Jun 4, 2011 | 12:09 PM
SpringerPop's Avatar
SpringerPop
No, they are separate circuits.
Do you have wiring diagrams, and do you know how to follow them? These are for your 2000. See below.
There are no stupid questions here at FTE.
Well............... mostly.
Pop
File Type: pdf
File Type: pdf
Old Jun 4, 2011 | 12:50 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Pop's got you covered with the Diagrams, Wow ever when I said too unplug your tail lights I was giving you a place to start and Isolate your tail lights from your problem. Unplug and fuse don't blow problem found, Unplug and fuse still blows time for more searching.
Old Jun 4, 2011 | 01:33 PM
Diesel 724's Avatar
Diesel 724
I disconnected the three plugs and it still blew a fuse....
Old Jun 4, 2011 | 02:09 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
OK now it's time to trace the harness back to the engine compartment for any places that look like they might have rubbed through.
Old Jun 4, 2011 | 04:09 PM
Diesel 724's Avatar
Diesel 724
I isolated the problem by pure stroke of luck. Its in my clearance lights some where. After market pieces of junk.
