Can't get injector cut tool to bite???
Old Jun 3, 2011 | 06:15 PM
JT250's Avatar
JT250
Any tips??
Injector cup...sorry
Old Jun 3, 2011 | 06:45 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Did you read this thread yet?
https://www.ford-trucks.com/forums/9...p-r-and-r.html
Old Jun 3, 2011 | 09:47 PM
JT250's Avatar
JT250
I read it but doesn't help me. I have one of the newer tools that threads in, but doest want to hold. IF I can get it to bite it won't hold when I tighten the pulled nut. Talked to clay several times today and he is gonna send me a new tool next week. It looks to me like the threads are flat "Stripped" so I think that I why they won't bite hard enough. I do like the design of the tool in the first post of the write up thread though....except the pulling the rockers part.
Old Jun 3, 2011 | 09:52 PM
7.3 Rocket's Avatar
7.3 Rocket
Can you give the tool a little love tap on top with a hammer to get it to seat into the cup a bit better?
I believe we did that with Jim (rat49f6)'s when we did them.
Old Jun 3, 2011 | 11:16 PM
JT250's Avatar
JT250
Yes I did that a couple of times. The last time was just a hair more than a love tap because Clay told me I could not hurt it. I got it to bite and it was way more than the 55-60 ft lbs (Clay also said that would be okay) but when I tightened the puller nut it just pulled out and had copper shavings in the threads. Just wasnt sure if anyone else has had this problem. I am going to try agian tomorrow, but I am not expecting any different results because I tried for over an hour. Definition of instanity....."Doing the same thing over and over and expecting different results" Hmmmmmmmmmmmmmmm.........
Old Jun 3, 2011 | 11:20 PM
7.3 Rocket's Avatar
7.3 Rocket
Well I really don't know what to tell you then other than I really hope that the new tool works out for you.
Old Jun 9, 2011 | 01:27 PM
JT250's Avatar
JT250
Update
Well I determined that the threads were damaged. Clay sent me another one but the threads were damaged on it also. He was about to send me a brand new one, but I was in a hurry, so I built my own and they came out easily.
I will be creating a thread on DIY injector cup puller in case someone gets in a bind like I did.
I don't blame Clay as it is the nature of the beast. These things happen.
Old Jun 9, 2011 | 01:36 PM
rat49f6's Avatar
rat49f6
I, had to beat then in and use more than the 55 lbs but got mine our once I got one the rest went well
Old Jun 9, 2011 | 02:35 PM
brownie83's Avatar
brownie83
when we did jims, we had to "adapt" the tool to make it work. after welding the lock nut, seemed to work fine, if i recall.
Old Jun 9, 2011 | 02:36 PM
JT250's Avatar
JT250
Tried that on both tools and I was way over 55 (after clays approval) and they either just stripped out or pulled out when I tightened the puller nut.
Old Jun 9, 2011 | 05:17 PM
SkySkiJason's Avatar
SkySkiJason
Glad ya figured it out!
I was there when Jim did his cups, so I called him to make sure thats what he did before I called you back. FWIW, I don't think a few brass shavings in combustion chamber will ever hurt anything.
Old Jun 9, 2011 | 05:58 PM
bama29fan's Avatar
bama29fan
Drop a penny in the bottom of the cup to prevent that
Old Jun 9, 2011 | 06:10 PM
JT250's Avatar
JT250
I don't either, but you can do the penny trick and vacuum it really well.
I read about doing that, but didn't end up searching for the coinage. I don't usually carry cash.
They are all in just letting them it overnight before adding water and cleaner.
Old Jun 9, 2011 | 06:16 PM
JT250's Avatar
JT250
Jason I tried to pm you but you are full
