Squealing accessory belts
Old Jun 9, 2011 | 12:52 PM
planehunter's Avatar
planehunter
Lots of great ideas here to help resolve your squeal noise. If after you get the alignment of the pulleys correct (major issue) and you still have noise try rubbing a little bar soap on both sides of the belt and see if this helps. If it does, you probably have a glaze issue on either your belt or pulleys. I had this problem from using cheap belts. I had to polish every pulley with some 400 wet/dry sand paper to get to go away, plus run quality belts.
