6.0 Help Info
Old Jun 3, 2011 | 04:28 PM
TheTowingCowboy's Avatar
TheTowingCowboy
6.0 Help Info
I got contracted to do a 6.0L Amarilo F350. Boy wants the baddest thing in town and has cash. So well I am new to the 6.0 I am use to the 7.3 so I want to know about how hard it is to change the Turbo and Injectors. He plans on having the truck at my place starting the 10th. He did really good at the last pulls bring in 2nd. I figured on a
Turbo:
ATS Diesel Aurora 4000 Ford Turbo System Kit
Injectors (Race 3)
Parleys Diesel Performance: Industrial Injection Full Set of New Race Series Injectors for 2004.5-2007 Ford 6.0L PowerStroke
Exhaust
MBRP Installer Series Aluminized 4" DUAL Exhaust System (Turbo-Back)(Off-Road)
Intake elbow:
CFM+ (CFM PLUS) Ford LargeMouth Intake Manifold Kit
Water/Meth:
Snow Performance Boost Cooler Stage-2
Now for a custom tune, any suggestions? And how hard is swapping injectors and a turbo? Thats my thing, nevver touched a 6.0 But I assume thats a good list?!?!
Old Jun 3, 2011 | 05:00 PM
utjer's Avatar
utjer
Change out the stock bolts with head studs. While you are at it, throw in a black onyx head gasket also.
Old Jun 3, 2011 | 05:17 PM
TheTowingCowboy
Well he doesnt want to do studs. So yeah. I know all that will work together and not cause hell but I never messed with a 6.0 so I wanted to know about how to change injectors (Which I found this SUPERB article)
Injector replacement - with pictures - Diesel Forum - TheDieselStop.com
Now just to know about how much of a pain int he *** the turbo will be.
Old Jun 3, 2011 | 05:24 PM
smokersteve's Avatar
smokersteve
NO STUDS!!??
Old Jun 3, 2011 | 05:28 PM
utjer's Avatar
utjer
With the power that truck with be throwing out he is crazy to not put studs on. I predict a quickly blown head gasket. If he has the cash as you say I would talk him into it.
Old Jun 3, 2011 | 05:56 PM
smokersteve
There is no need for black onyx, many use stock gaskets with high power trucks.
Old Jun 3, 2011 | 06:02 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
I would do studs or not take the job unless you get him to sign a waiver releasing you of responsibility when the HGs let go. It's not a matter of if but when and I'd say it will be very soon after the mods are done. Otherwise, he might come back at you when they fail blaming it on something you did and it's not just worth the headache.
Old Jun 3, 2011 | 07:07 PM
brickie's Avatar
brickie
The fuel system needs major upgrades for those injectors.The stock head bolts won't last a single wot run on that motor.
Old Jun 3, 2011 | 07:16 PM
TheTowingCowboy
Well he dont want head bolts, so drop the turbo size and injectors down? Or are head studs all that hard cause I don want to take the heads off. SO I assume like the 7.3 replace them one at a time?
Old Jun 3, 2011 | 09:40 PM
Unrealo4's Avatar
Unrealo4
Without doing headstuds he's going to blow his HG's with just a mild tune
You came here seeking advice about the 6.0. Now do yourself and your client a favor and install arp studs. Also you could save 2k and use a garret powermax instead of the aurora Turbo. That alone should be the cost of arps and gaskets.
Old Jun 3, 2011 | 11:50 PM
smokersteve
Well put!
The powermax is $1,500-$1,200. Many use it and love it. It would be better IMO to do the PM, 190cc from caserly, airdog fuel pump, arp head studs, stock head gaskets, and tuning, S&B intake and 4" turbo back.
