Spark Plug Boots
Old Jun 3, 2011 | 09:57 AM
makthenif's Avatar
makthenif
Spark Plug Boots
is it a good idea to change the boot when changing the plugs?
Old Jun 3, 2011 | 10:52 AM
lv2race's Avatar
lv2race
They're so cheap, it wouldn't hurt. I got mine at NAPA for $4.42 and they come with the spring wire. They also give AAA discount.
Old Jun 3, 2011 | 11:52 AM
alloro's Avatar
alloro
Each or for a set?
Old Jun 3, 2011 | 03:11 PM
lv2race's Avatar
lv2race
Originally Posted by alloro
Each or for a set?
Each, with spring.
Old Jun 3, 2011 | 03:56 PM
alloro's Avatar
alloro
Each, with spring.
Ouch, that's expensive considering you can get a set of all 8 COPs complete for $79.
Old Jun 3, 2011 | 04:32 PM
R&T Babich's Avatar
R&T Babich
So the boots and springs would be around $38.
That's about right, the coils are a bit over half the cost.
The coils are easily tested.
Why change the coils when it's more likely the boot or the spring is the problem?
Old Jun 3, 2011 | 05:02 PM
lv2race's Avatar
lv2race
I know, but with the P0305/0306 code the other day, I needed them NOW to zero in on the issue. It was only $9 and 30 minutes and I got my answer.
Old Jun 3, 2011 | 07:48 PM
alloro's Avatar
alloro
I guess it depends on how much you value your free time. To me it's not worth saving the $41 to spend the time cleaning, testing, then changing the boot and spring on each of the old COPs. Then there's the possibility that even if all the COPs test good, one might be borderline not good. You could put it all back together and still end up with a misfire. But that's just me! I learned the hard way that it's okay to be penny wise, as long as you're not dollar stupid.
Old Jun 3, 2011 | 07:51 PM
alloro's Avatar
alloro
Good I'm glad to hear it worked out for you. When I changed my COPs I kept a few known good ones, just in case I ran into a 'I need to fix it now' situation like you did.
