2008 5.4 F350 with 66k miles
Does anyone know how these 5.4s are? I'm looking at an 08 with 66k miles on it. Is that high miles? I cant touch the diesels or anything with lower mileage. These trucks seem to really hold there value. Any thoughts? My cousin sells Chevrolet, so thats what I have. I gotta get out of this thing. I need my Ford back.
The 5.4 is capable for light to medium towing and will haul up to your payload capacity with no problems. It will rev high, but it is designed that way. It won't be the fastest thing on the road either, so don't buy it and then complain that it is slow or "what can I do to get more power out of this DOG!?" as some members here have done.
66K is not high miles, just as with anything, it has been maintained properly. If it has, and you continue, it should last over 200K. The Ford Modular Engines are excellent.
I'll ride right along with JC on his comment. It isn't a drag truck but if you rev her she'll do what needs done. About the only thing to wake it up is steeper gears. Anything that goes wrong with it has been covered here and if you're handy with a wrench at all you can fix it. Mine just rolled 70k and runs like a top.
I love my 5.4, I don't tow very heavy (7-8,000) and Kansas is pretty flat so I've never lacked for power or speed for that matter. If I towed much heavier or anyplace w/ hills I'd want better gears but the 3.73's have worked fine for me so far.
Great engine and no that is nothing for miles. That's why they hold there value so well. Get maintenance records if u can. Check for broken manifold studs. Check ball joints,wheel bearings,and just the front end in general. If u get it Change all the fluids for a fresh start. My 03 f350 xlt does anything and everything i need it to and then some. I love my 5.4!
My 08 has 84K on it. No leaks, doesn't use oil. Tows my 3 horse trailer w/ living quarters (about 7-8Klbs) just fine. 4x4, ball joints are still tight, no play. Great truck. I wouldn't worry about 66k as long as it was maintained. Beware, you are right at spark plug replacement time, which can be an ordeal. Tranny fluid change is also a $400 dealer cost.
