View Poll Results: If you use this, have you noticed your fuel economy to be better or worse?
Better
79.17%
Worse
20.83%
Voters: 24. You may not vote on this poll
Motorcraft Cetane Booster and Performance Improver
Old Jun 2, 2011 | 08:52 AM
Hu Slung Pu's Avatar
Hu Slung Pu
I was using it at every fill up, but I only get around 13 in town. I have a lot of stop and go traffic, but still it sucks. I thought about not using it just to see if it improves. So, here's my question; for those of you who use this, do you see any difference in fuel economy?
Motorcraft® Cetane Booster and Performance Improver
  • Helps improve Ford diesel engine performance
  • Note: This ultra-low sulfur formulation can be used in engines required to meet 2007 emissions requirements (e.g., Ford’s 6.4L diesel engine) and is backward compatible as well (i.e., can be used in Ford’s 6.9L, 7.3L and 6.0L diesel engines)
  • Ultra Low Sulfur Diesel (ULSD) compliant
  • Combats the effects of poor-quality diesel fuel
  • Boosts the cetane rating (fuel ignitability) of diesel fuel for improved starting performance
  • Increases power
  • Helps smooth engine operation
  • Improves fuel economy
  • Adds lubricity to fuel to reduce engine wear
  • Recommended by Ford Motor Company
  • Available in four (4), six (6) or twelve (12) 20-fluid-oz. bottles
Old Jun 2, 2011 | 09:13 AM
Biggziff's Avatar
Biggziff
I don't use it, but my take is this...for the $8 or so it costs per bottle it would be impossible for it to ROI and as Ford doesn't say you have to use it to keep the truck under warranty I'd pass. There are way too many people driving diesels successfully who don't even know about this stuff to merit it being used at any cost, IMO.
Old Jun 2, 2011 | 09:16 AM
Hu Slung Pu
True. I guess I like the lubricant aspect of it as well. It makes me feel like I'm doing something extra to help the longevity of the engine....I guess. I don't know. That's why I'm on the fence about the stuff.
Old Jun 2, 2011 | 09:31 AM
Biggziff's Avatar
Biggziff
I understand and can relate, but...I have to think that they are marketing to us by using those emotions which makes me skeptical.
Old Jun 2, 2011 | 09:47 AM
kper05's Avatar
kper05
I use it because I've read it helps with the fuel system components.
I've lost 1 MPG this summer from last summer but I can't prove it is because of this stuff.
Both fuel filters, both air filters and a different fuel station has not helped.
I also had algae in my DFCM fuel filter so it didn't prevent that but drained the DFCM monthly without water.
If I didn't use it, I don't know if the algae problem would have been worse or the same.
At this point, I use it "just because" others say it is helpful for our expensive fuel system and for no other reason.
Edit: I should report I changed fuel stations after the fuel filters change close to 1,000 miles ago.
Air filters about 1,300+ miles ago.
Old Jun 2, 2011 | 10:28 AM
Marauder92V's Avatar
Marauder92V
I have seen no change in fuel economy (you might want to add that to your voting box). I think if there is any benefit, it is to help with lubrication -- and the benefits won't be apparent to me because I won't be tearing down 2 engines (1 using, the other not) and putting a micrometer on all the parts
I also think the anti gelling is important and use one with this agent.
Old Jun 2, 2011 | 10:34 AM
Marauder92V
I remember seeing your photos. I had an Uncle who did deep sea charters with a boat with diesel engines. I remember him telling me that algae growth was a problem and that he used an agent to handle it. Wonder if this would help your situation. I don't think Ford's Cetane additive is designed to deal with this problem.
Old Jun 2, 2011 | 10:35 AM
Biggziff's Avatar
Biggziff
I guess if you're planning to keep the truck forever and you could get some proof it adds to the longevity then ya..it may be worth spending the money.
The anti-gelling thing has me wondering also. I have 2 friends with diesel trucks that are daily drivers. These guys are NOT mechanical and have never added anything to the tanks other than what comes out of the pump. They don't plug the engines in during the winter and have never had any issues with trucks not starting or running right in the cold.
Not scientific, but certainly interesting.
Old Jun 2, 2011 | 10:44 AM
Marauder92V
Depending on your driving style and where you drive, the MPG is going to vary. My around town driving (50% stop & go, 50% on road with minimum stops) will yield a 14.5 to 15.5 MPG. When I go into town and that percentage goes closer to 75% stop & go, my MPG drops to the 13.5 to 14.5 range.
Add in a heavy foot, it is easy to be in the 12 - 13 range...
The way I look at it is that 15 MPG is better than all of the trucks I have owned...
Old Jun 2, 2011 | 10:50 AM
Marauder92V
I think the main benefit of the anti gel is when you are consistently below the freezing point of diesel (15F). I believe it begins to cloud at 32F. The guys way up north, where temps don't get above freezing for long periods of time probably have a better read on what happens if you don't use it.
Old Jun 2, 2011 | 01:37 PM
dschuffert's Avatar
dschuffert
I have seen no change. I have used it, per the direction on the bottle, with every fill-up over the last 2,000 miles.
Old Jun 2, 2011 | 05:55 PM
sparky1166's Avatar
sparky1166
I use it every other tank. It may not be doing much, but it gives me that warm fuzzy felling.
Old Jun 2, 2011 | 06:14 PM
kper05's Avatar
kper05
I know several other diesel owners who don't add anything.
Powerstroke, Cummins and Duramax.
Pump from the station and go.
On a side note, does anyone see any issue with adding the 4 oz of this stuff with the engine running at idle?
The times I have done this (3-4 maybe) I am ready with the fuel nozzle and pump at full speed to mix as quickly as possible.
It could be 5-10 seconds between the two though.
Old Jun 2, 2011 | 06:31 PM
turbohunter's Avatar
turbohunter
Hi Guys
A 6.4 guy chiming in here.
It also depends on the quality of fuel you buy.
If you buy from Slippery Louies gas and Cathouse you may want to use it. Especially because of water in the fuel.
If you buy from a Chevron or 76 or other reputable joint maybe not necessary unless you like warm and fuzzy (I admit I do. Just paranoid I guess)
Cheers
Old Jun 2, 2011 | 09:05 PM
FishOnOne's Avatar
FishOnOne
A 6.0 psd chiming in also. I've tried just about every brand of fuel additive and the Motorcraft brand was the only one that I saw a honest improvement in fuel economy.
This is the only brand I can really recommend based on my experience in the 6.0psd.
