So the x monitor is getting the signal before the truck computer does and is reading correctly but maybe corrupting the signal down line from it is what your theory is. I will have to try unhooking the x monitor tonight
There really should be interferance between the two. It is possible that there could be some corrosion where we are making the connection which could be causing some resistance. I would take the connection apart where we make the connection check to make sure there is no corrosion. Put a little dielectric grease back into the connection and see if that corrects it. The readings in the Xmonitor are very sensitive to ground. You might want to check the ground to the control module as well. Make sure they are clean and solid.
That's correct. But the x monitor that he's speaking of, sold by BD Diesel Performance, gets it's transmission temperature by tapping into the TFT sensor wire. My theory is that the x monitor is interfering with the computers ability to properly read the TFT sensor, not that the Scanguage is interfering with anything. It's just reporting the TFT value given it by the computer.
10-4, I can see how that could happen. I was thinking also about how the x monitor works. what if it were wired in series to the existing circuit when it should have just been tapping into it, or vice-versa?
I guess what makes me question the scangauge is the fact that it starts out 20 higher than ambient temp and stays higher than my other gauge
Hey cak301,
Just for reference, I made a note of my scangauge readings this afternoon when I got off work. My airconditioning panel said it was 102 outside (dang hot). Immediately after cranking up I got these numbers:
109 fWT (Coolant)
109 EOT (oil)
104 FIA (intake air #2)
110 TFT (trans)
The truck had been sitting in the sun in a parking lot for 8 1/2 hours, I guess there could have been a little bit of heat left in it from the morning drive, but as you can see my #'s dont agree dead on either but it is pretty close and I think by the time its in the 130-150 range I'm trusting it to be Right. If the wiring looks ok, I'd double check the setting for the TFT parameters in the scan gauge. These are working well for me:
Well I tried unhooking the X monitor and it didn't seem to make any difference in the readings on the scangauge
you could try and reset it
If you think its the scangauge call them I think all the fluid temps should be about the same after cold soak
see how all rusty axelrod fluids temps are really close at his start
Intake air can be off a little because its not a fluid but should be close
mine would read mpg all over like 10mpg and bounce to 9999mpg at a very rapid rate they sent me a new one no??? I sent the old one back they paid all shipping everything I had good customer service
unless the sensor bad tft do you have any cel on any codes
My first SGII read 46 FICM volts even though it was 48 at the FICM screw. My second (beta test unit) reads right on the money. FWIW-- my 04 doesn't read codes at all on either unit and I know it has 2 for sure.
I agree in the code reading. It's advertised as CAN compliant but I seen several posts where it's not reading vehicle specific codes. I'm not too interested in the trip computer functions either though. Just need some gauges.
What are the xgauge codes for reading FICM voltage?
Here is a thread with a lot of codes. If you read through it ther is a link to an Excel spreadsheet you can print page 2 and have 'em all on one page.
Maybe this thread should be in the tech folder?
My SGII picked up codes on my 04. The one code I kept getting, which lit the CEL, was P0488. I haven't seen the CEL for quite sometime now, since I cleared it with the SGII.
I did enter the DTC gauge which counts, from what I understand, the "soft" codes until the "soft" code reaches a particular count which then throws the CEL.
I'm not sure if I am understanding that right, I'm just not sure.
