Gear Ratios
Old May 30, 2011 | 04:38 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Gear Ratios
I think I am running 3.73 but I will check later. My question is what is the difference in the gears. I know 4.10 was also offered but you can get other gear such as 4.53 (I think thats what it is). What would be the pros/cons of the different ratios?
Old May 30, 2011 | 04:50 PM
hanklin's Avatar
hanklin
I run 3.73 and have no issues at all. I tow just fine ans I get better fuel mileage. Thats my vote
Old May 30, 2011 | 04:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I wasnt asking for opinions, because I have no problems either. I am more just in search for knowledge.
Old May 30, 2011 | 05:01 PM
hanklin's Avatar
hanklin
Then what the heck is the difference between "what would be" and "opinion"? You asked about pros and I stated that 3.73 tows fine and great mileage,sheesh
Old May 30, 2011 | 05:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Im sure the 4.10 offers towing and good mileage too, but which is better at what? They are different, I just wanna know what about them is different.
Old May 30, 2011 | 06:01 PM
joeyd61's Avatar
joeyd61
it depends on other things...Tire height??? stock, 3.73 is good all around...I run 37" tires and use 4.56 gears,they are a little low but i love the pull/towing the truck has....if your gearing holds 1800-2000 @ 70mph while towing i would think you are good...if you use 4.30 with stock tires, it will tow/pull stronger but you RPMs increase at crusing speed which means less MPG....just my 02....
Old May 30, 2011 | 06:16 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thats more or less what I was looking for. Higher gears will raise RPM.. Better for heavy towing, worse on MPG?
Old May 30, 2011 | 06:25 PM
ToMang07's Avatar
ToMang07
If you Do HEAVY pulling... Get the 4.56 gears.
Light to moderate pulling... 4.10.
Light pulling and DD... 3.73.
I do mostly daily driving and plowing, with some moderate pulling.... and LOVE my 3.73's.
Puts me right at 2,000rpm's at 70mph, and I get 16-18mpg regularly.
Old May 30, 2011 | 06:31 PM
joeyd61's Avatar
joeyd61
Higher gears will lower RPM,(good if you want to run 85mph@1800rpm) Lower gears will Raise RPM (for towing/pulling)
X2
Old May 30, 2011 | 06:34 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Perfect. Answer give. Thanks
Old May 30, 2011 | 07:00 PM
cps's Avatar
cps
And if you go to Randys Ring & Pinion web site they have all the info you need for calculating RPMs & MPH versas gear ratios. Very easy to figure out what you need.
