clutch
Old May 30, 2011 | 09:48 AM
kingnothing1's Avatar
kingnothing1
clutch
ive got an vibration in my clutch pedal and at like fifty the gas pedal viberates also. it goes in and out of gear fine. its not an install issues ive been driving the truck for close to a year.
Old May 30, 2011 | 10:12 AM
billt28's Avatar
billt28
Have you checked your mounts?
Old May 30, 2011 | 10:16 AM
kingnothing1
if it was pressure plate or throw out bearing what would i look for.... would i check trans or motor mounts
Old May 30, 2011 | 10:19 AM
billt28's Avatar
billt28
If it was a pressure plate, check for missing springs. If it was the TB, it'll squeal, or whine from being dry. Check both motor mounts, and your tranny mounts. What engine, year, trans? Also check your bell housing for cracks, or broken mounting tabs.
Old May 30, 2011 | 11:50 AM
kingnothing1
mounts look good its a str8 six 4.9L its an 85 bronco not sure of trans its a manual with 4wd
Old May 30, 2011 | 08:07 PM
glovemeister's Avatar
glovemeister
I'd look at alignment and your tires in balance, and drive line balanced. Personally, I like vibration (not much but some, and some noise) it lets me know the truck is running. With a stock exhaust my Dodge truck was so quiet that I wouldn't even know it was on. My Ford on the other hand pretty quiet but enough vibration that I know shes good.
Old Jun 6, 2011 | 04:54 PM
kingnothing1
through some more (Accidental) searching the problem was the drive shaft had broke the u-joint
