Auxiliary Fuel Tank
Whats the actual problem?? If jelly got into the tank it would contaminate the fuel. I would guess it would wash down pretty quickly, so shouldn't cause any issues with filling. There might be a venting issue elsewhere though.
for my 100gallon i took a 1/2" hydraulic pinch fitting, drilled my tank on the flat back side of the front tank and on the flat neck side on the rear, ran 1/2" line to a ball valve each, come together in a T then with 1/2" pipe runs into the bottom bung of my tank. all 1/2". dont go smaller, and make sure you have a way to vent your in bed tank or it will never fill. it will quit flowing from the suction and take forever to get one "glug" of air from the line let alone enough to flow 37 gallons
Everyone that has taken it out has noted an improvement in filling. I don't have anything to base it on yet, as I pulled it out of the front tank when I replaced it, but the front tank had a leak when I bought the truck so I didn't get a chance to compare before and after. I've yet to do the rear tank, but will soon (because it rusted it now...grrr)
90pioneer
22
09-15-2017 09:35 PM
dieselsubmariner
04-15-2016 10:00 AM
StanleyZ
6.4L Power Stroke Diesel
16
10-23-2013 05:47 PM
