Ok, I can't seem to create a signature. Not sure why, I see some people have them, some don't. Just curious if I can have one, and if I can, what am I doing wrong??
Try logging off, clearing your cookies, etc. Then log back in and see if it helps. If you've gotten the required 25 posts to add a sig while you've been on here and haven't logged off and then back on, the software may not have reset to show your new capabilities as of yet.
I have tried from 2 different computers, still no go. (Work when I made the post, Home now.)
I will try to clear the cookies in a little bit. Just kinda annoying.
Do you log in each time or do you have the "Remember me" box checked?
Work computer ALWAYS clears cookies/cache. (Manually and automatically.)
Home one... not sure. I had to log in when I opened the window. Im workin on some stuff now, but the soon as I'm done I will clear the cache and see if that works or not.
Your profiles is fine it is for sure on your end...sorry
I sent you something I want you to do
With the exception of the defrag, I did everything you said last night. I'm on a work computer now, and still no change. I will try again tonight when I get home with the defrag... But I don't think it will make a difference.
OK this is weird if it does not work...what do you want in your sig...let me cut and paste and see if we can get it that way...
Start
