Leaf Spring Bolt help!!
Old May 29, 2011 | 01:14 PM
rfdepew's Avatar
rfdepew
93 F-150 Supercab 4x4 351W
I am Having an issue removing a stubborn leaf spring front frame bracket bolt. Been hammering away for 60 min now . Do i need to burn it out or what? Suggestions appreciated. Have no means to burn if I need to what is a lowes recommendation if they even have something to burn with.Afraid back bolts will be the same or even the other side
Yea I live in the rust belt
Thanks for any advice<O</O
Old May 29, 2011 | 01:31 PM
Lazy K's Avatar
Lazy K
I would think you are going to have to cut through the bolt, between the spring hanger and the spring eye to get that out.
If you can cut through the bolt between the eye and hanger at the end with the head on it you may be able then to cut the threaded end off on the outside of the hanger and lever the spring eye out.
All I can think of.
Old May 29, 2011 | 01:32 PM
bashby's Avatar
bashby
Got a sawzall?
Old May 29, 2011 | 01:35 PM
rfdepew's Avatar
rfdepew
Originally Posted by bashby
Got a sawzall?
Was so mad at it never gave it a thought a sawzall
I got one in the basement, now to find where i put it.
Thanks Guys
Old May 29, 2011 | 02:12 PM
firewood truck's Avatar
firewood truck
I'm in Baltimore so my F250 was just as rusty, my solution was a 4-1/2" grinder with cut off wheels, it went through those bolts like butter!
Old May 29, 2011 | 02:20 PM
seventyseven250's Avatar
seventyseven250
The problem is that the steel on the inside of the bushing has rusted to the bolt. The rubber gives it a little bit of "give" when you hammer on it so that is pretty useless.
Cutting it out is the best idea, heating it until the rubber burns out will also work if you have nothing to cut with, but it's not the preferred method. Don't ask . ..
Old May 29, 2011 | 03:18 PM
bashby's Avatar
bashby
Makes some pretty nasty black smoke when ya burn 'em out... doesnt it?!
Old May 29, 2011 | 04:56 PM
rfdepew's Avatar
rfdepew
Found the sawsall now to the store to get blades. have not used it in years.
Was so mad at it was not in the right frame of mind. Will cut them buggers off in the morning
Thanks
Again
Old May 29, 2011 | 05:20 PM
bashby's Avatar
bashby
I've noticed the dewalt blades are pretty good, tried cheapo's... they sucked.
Old May 29, 2011 | 10:33 PM
ostrx250's Avatar
ostrx250
i used a 3 inch cutoff tool to cut those off my 88 but wear gloves and if you can get a old shirt and wet it youll have a spark shower if you get down there. good luck tell us how it goes
Old May 30, 2011 | 06:32 AM
deeznuts822's Avatar
deeznuts822
I use a balljoint press to get those out.
Old May 30, 2011 | 07:55 AM
bashby's Avatar
bashby
I've done that also, works pretty good if you've got room to get it on the bolt.
Old May 30, 2011 | 08:05 AM
raytasch's Avatar
raytasch
Believe Nothing
Such an easy job with a press when the bed is off If the bed is still on, cut off wheel or sawzaw as mentioned. Do wear good eye and ear protection.
Old May 30, 2011 | 09:13 AM
ford351powr's Avatar
ford351powr
I used a Hilti chipping gun on mine, after beating it for 20 mins with a hammer. I had the sawzall on the ground next to me, something about rusty parts makes me lose my mind.
Old May 30, 2011 | 08:54 PM
seventyseven250
Truly awful .. .
Be safe out there, wear some eye protection, decent gloves, and watch out for sparks and fires . .
