i was wondering if the <a href="http://motorhaven.autoanything.com/">460 </a>was offered in 73 f-100 rangers. Im picking on up, and i'm just kinda courious as to whether or not this thing is stock.
That depends if it's 2wd or 4wd. If it's 4wd, to the best of my knowledge, it was never offered. No 73-79 4WD f100/f150 ever came with a <a href="http://motorhaven.autoanything.com/">460 </a>from the factory (or so I'm told). It is a popular swap though.
No ford 73-9 4x4 F100 F150 F250 F350 came from the factory with a 460. I think that they were offered with a 300I6, <a href="http://www.motorhaven.com/">351m </a>and 400. In 73-6 you could get a 352, 360, 390, and I think a 428. Hopefully you don't have a <a href="http://www.motorhaven.com/">460 </a>IMO.
I believe that we have already established that the truck is a 2WD. So the <a href="http://www.motorhaven.com/">460 </a>was an option. Are you sure that it is not a 360? Just curious.
Jimmy
Well the guy said it was a <a href="http://www.motorhaven.com/">460 </a>that had been slightly built up by some local shop before he bought it. Im guessing its a nice running motor since he told me that the engine was the only reason he bought the truck. I havent heard her run yet but i will before cash exchanges hands.
Btw this thing also needs a radiator, i have found 2 for 50 bucks. But a buddy of mine has one out of an 85 f150 with a 300, would that rad work? I'm hoping you guys can save me some run around time with that one .
No on the radiator. You Can use one for a 351/400 with a/c. I have a 351 3 core in mine with a 460. It stays around 200 in the summer. It has never gone over 220 and that is in 95 degree weather towing a load. The <a href="http://www.motorhaven.com/">460 </a>had a 4 core radiator. It's about $100 more than the 3 core.
Jimmy
Well i just found out he has a radiator out of a 351 so it looks like im in luck. I also found an electric fan for 60 bucks in jegs, how much would this help the cooling?
It's important that the radiator is a 3 or 4 core model that came from a <a href="http://www.motorhaven.com/">429 </a>or 460. I think you can use one that was in front of a <a href="http://www.motorhaven.com/">390 </a>as well since your truck is a 73. If you get one from a junkyard make sure it holds water so you don't pay through the nose to have it re-cored.
