brake problems
Old May 28, 2011 | 09:25 AM
bruce78's Avatar
bruce78
brake problems
I just bought an 83 f150. I started driving it and when it gets hot all the brakes lock up and will not release. After it cools down the brakes work fine until it heats up again.does anyone have any ideas
Old May 28, 2011 | 09:37 AM
Caleb H's Avatar
Caleb H
Is it just the front or the rear? Try replacing the calipers; they may be old and rusted which can cause that to happen.
Old May 28, 2011 | 09:43 AM
bruce78's Avatar
bruce78
its all four wheels
Old May 28, 2011 | 10:13 AM
bashby's Avatar
bashby
Crack the bleeders loose and see if it releases. If so your master cyl pushrod may be too long. Have you done anything with the brakes lately? To test the long pushrod theory, when the brakes are locked, loosen the 2 bolts that hold the master cyl to the booster to let them seperate 1/4" or so.
Old May 31, 2011 | 09:51 AM
bruce78's Avatar
bruce78
thanks ill try that i have not done anything to the brakes yet the truck has been sitting for 2 yrs . its wierd it only happens when the enginge gets hot
Old Jun 1, 2011 | 05:42 PM
85_Blue's Avatar
85_Blue
Bruce if you live in a humid area, drain the lines and refill. Then use a dot3 and see if that gives you a baseline to work with.
