turn signal switch
Old May 28, 2011 | 12:46 AM
pro70golfer14's Avatar
pro70golfer14
turn signal switch
My turn signal switch has went bad in my 78. Where is the cheapest place you all have found to get one of these? and have you all had much success with replacing just the the plastic assembly for ten bucks from advance auto, or just go ahead and do it right and replace the whole thing.
Old May 28, 2011 | 12:53 AM
montana_highboy's Avatar
montana_highboy
Shop your local parts stores, about $60 is the best you'll do, i believe all those TSS are made by Shee-Mar inc.
Old May 28, 2011 | 01:09 AM
pro70golfer14
yea thats the reason i asked because i seen all of you guys are getting them for 40-60. and the best i found is 95.
Old May 28, 2011 | 09:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978/79: F100/350, Bronco & Econoline T/S Switches
There are THREE different T/S Switches.
D8TZ-13341-A .. T/S Switch-Use with Tilt Wheel only / Obsolete
COLLECTORS AUTO SUPPLY in Oroville WA has 1 = 800-414-4462.
JST AUTOMOTIVE in Lebanon TN has 1 = 615-443-3086.
D8TZ-13341-B .. T/S Switch-Use with A/T w/o Tilt Wheel / Available from Ford.
MSRP: $110.00 // FTE sponsor PARTSGUYED.COM price: $79.20.
D8TZ-13341-C .. T/S Switch-Use with M/T w/o tilt wheel / Obsolete
COLLECTORS AUTO SUPPLY has 1.
GREEN SALES CO, in Cincinnati OH has 2 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 2 = 606-787-5293.
MILLER OBSOLETE PARTS in Binghamton NY has 15 = 607-722-5371.
Be aware that the Tilt Wheel on vehicles of this vintage is operated by the turn signal handle. Press it forward: BOING!
Old May 28, 2011 | 09:41 AM
trap4x4's Avatar
trap4x4
Like N.D. said there are 3 different ones .... B & C I've found on E-gay , The A model is harder to locate and mucho $$$ .... If you need the tilt one, Here is a link that i ordered from ....
Lighting Parts - Turn Signal Switch and Mounting Plate : 1948 - 1979 Ford Pickup Online Catalog - Page 103 : Obsolete & Classic Auto Parts Online Catalog
Give it a sec to down load ... pg 103. There is a typo in the description of the D8TZ-13341-A model ....
Not sure why the A is cheaper thru these guys .... Havent got it yet so cant comment on the quality
