6637 question
Old May 25, 2011 | 01:02 AM
hhowell1990's Avatar
hhowell1990
6637 question
I ordered my 6637 kit yesterday night from clay and just wanted to know if there'll be a noticeable difference as far as performance, MPGs or both once installed?
Old May 25, 2011 | 01:04 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
When I installed mine I also did a 4" exhaust back from the turbo. Most people would recommended getting some sort of exhaust upgrade because when you upgrade the input you should upgrade the output, too.
I did notice a 1MPG increase in city driving, but as I said that was with an exhaust also.
The one thing you will notice is it will be louder.
Congrats!
Old May 25, 2011 | 01:12 AM
hhowell1990
Congrats!
Thanks exhaust is my next upgrade, the only reason i did the 6637 first was because of it being about an eigth the price of the exhaust and funds for me are a bit short right now.
Old May 25, 2011 | 01:14 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
No worries, I'm in the same boat. Doing one before the other wont hurt ya, but you wont get the full benefit of either with out the other.
Old May 25, 2011 | 01:19 AM
hhowell1990
I do have a question though about doing my exhaust, I've got an appox. 8 ft section of 409 stainless pipe from exhaust on my boat that I never got around to doing, would it be a straight enough shot from the down pipe to an aftermarket 4" tail pipe to use that pipe or would i have to use a kit to have the proper bends in it??
Old May 25, 2011 | 01:21 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Once you get past the down pipe its a straight shot to the rear axle. You would either need to go up and over the axle or just cut the exhaust before the axle and have it end at the front of the bed area. But I believe you would need a 4" down pipe too, unless you adapted it to the factory down pipe, but then youre really not getting any benefit.
Old May 25, 2011 | 01:26 AM
hhowell1990
I had planned on ordering a downpipe and tail pipe from summitracing which would set me back about half what an exhaust system would cost I'm just wondering if it would leave the tip of the tail pipe at a funky angle because of the stock tail pipe exiting the stock muffler on the top and the intermediate pipe entering from the bottom
Old May 25, 2011 | 01:31 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I'm not sure. Ive never seen a stock muffler, mine had a round aftermarket one when I did my system. I would recommend getting an aftermarket system. Check my sig for the one I got. Its only about $300. If you just replace the down pipe and intermediate pipe you still how a 3" muffler and tail pipe, not to mention the stock muffler is pretty restrictive.
I would just save up and get a full kit. It will be better in the long run IMO.
Old May 25, 2011 | 07:51 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
I did 6637 only and went from (truck by itself, cruise set, 73mph, 90 miles) 17.1 to 19.0. I installed it last Friday before I went to my camp site. Same stretch of road, cruise set same. It was as even of a test as I could do.
And driving it to work and back I have noticed a slight increase as well. I used to get 15.9-16.3 ish in combo country and city driving. Now I seem to be hanging closer to 17.
Oh and for the record it's a 2000 crew cab long box 4x4 3:73 gears, no mods other than the air filter. Well and some guages, and the previous owner put a thumpity thump stereo in it, but that doesn't effect mileage much.
Old May 25, 2011 | 07:56 AM
Kwikkordead's Avatar
Kwikkordead
You can get rid of 95% of the exhaust restriction simply by eliminating the muffler and putting a (very inexpensive) piece of straight pipe in it's place.
You'll notice that it's noisier, but with the turbo quieting things down it will be like putting a set of glass packs on a gas engine.
Nice mellow rumble.
Old May 25, 2011 | 11:03 AM
SteveH-CO's Avatar
SteveH-CO
I just did a 6637 - nice MPG gain. Along with a lighter foot on the freeway and fixed boost leaks, I went from high 13s to high 16s, for MPG. I have a stock exhaust system and no other significant mods other than the Hutch mod.
You will hear turbo farts (I believe that's that term) on up shifts and if you quickly lift off the throttle under boost. I'm ok with that. I feel a stronger off-the-line and mid-range pull.
Protect the 6637 or sleeve on the filter by covering any rough spots under the hood where the filter sits. What I'm trying to say is that after you remove the factory air box be aware of the sharp plastic bits that remain, as they will wear through your cloth cover, if you have one.
Old May 25, 2011 | 11:19 AM
mtdigger's Avatar
mtdigger
I have a home made 6637 with donaldson filter, and just cut the muffler off my 99,5 350 dually, its loud, but I like the noise, don't know about mpg, but its crisp when I jump on the go pedal, so opening up the intake and exhaust gives a nice seat of the pants boost, and she sings like a bird at all speeds
Old May 25, 2011 | 03:20 PM
hhowell1990
Yeah i think for the time being I'm just going to straight pipe my exhaust, then when i get enough spare cash I'm going to order the full kit.
Old May 26, 2011 | 10:46 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I would have gone with a straight pipe but I'm in CA and we got strict laws. I couldnt find a for sure answer so I left one on.
Old May 26, 2011 | 11:36 PM
hhowell1990
How much of drop in EGT temp should I expect from running a straight pipe?
