computer?
Old May 24, 2011 | 11:36 PM
CPFR1924's Avatar
CPFR1924
computer?
my truck: 96 f150 5.0 5spd 4x4.
its started about 2 weeks ago running very rich and idling very rough on my way to work, on my way home (10 miles) it used almost a 1/4 tank of fuel. i tryed pullin the codes but the reader just says no link, iv replaced the plugs, wires, dis cap, fuel pressure control moduel, ignition control moduel, fuel pump relay, and the pump in the front tank. then i realized that the fuel pumps are not ever shutting off even with the key on motor off they will continuesly run. then i realized that while he truck is running i i switch to the rear tank (its compleatly empty) it will run just like normal untill it starts starving for fuel so i can switch back to the front it will start running rich again.
a friend said it was most likely the computer, but i wanted to get someones opinion before i replace that, so anyone have any ideas
Old May 25, 2011 | 06:48 AM
Edgethis's Avatar
Edgethis
I think if the computer was bad you wouldn't be able to drive it normally, rich or not. I would recommend double checking everything you already did and maybe unhook the computer and wait a bit then plug it back in.
Old May 25, 2011 | 09:37 AM
CPFR1924's Avatar
CPFR1924
So any idea why the fuel pumps will not shut off
Old May 25, 2011 | 09:57 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Does the pumps do the 2-3 second priming, and just never shut off? If so, talk to Bill, aka Subford on here...He is a electronics wiz....
Old May 25, 2011 | 10:37 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/8...tinuously.html Read this link. Do what Subford says to test it but it does sound like a bad computer.
Old May 25, 2011 | 11:55 AM
andym's Avatar
andym
It does sound like a bad computer. That's what they do when they fail.
Old May 25, 2011 | 01:06 PM
lew52's Avatar
lew52
My computer has been running slow lately , where do i find these fuel pumps ?? its a Dell
Old May 25, 2011 | 01:13 PM
Duct Tape Racing's Avatar
Duct Tape Racing
thats awesome
Old May 25, 2011 | 01:40 PM
CPFR1924's Avatar
CPFR1924
Would the fuel pumps running like that because of the computer being bad cause it to be running like it is?
Old May 25, 2011 | 03:55 PM
subford's Avatar
subford
Yes.
Sounds like it is in limp mode.
Old May 26, 2011 | 07:58 AM
90Utah150's Avatar
90Utah150
I had a problem with the fuel pump running after I shut-off the truck. I smacked the Fuel Pump Relay, not too hard. It stopped, so I figure the relay was stuck.
Old May 28, 2011 | 04:26 PM
CPFR1924's Avatar
CPFR1924
ok so i just put the new computer in and there is no change its still running the same, when i first turned the key on the fuel pump ran 2-3 seconds cut off i fired the truck up it ran great for about a min then it bogged down and is right back to doing the exact same thing, fuel pumps are still not shutting off!?!?!?!?!?!?!?!
Old May 28, 2011 | 04:28 PM
Edgethis's Avatar
Edgethis
Did you smack the relay?
Lol seriously tho. Maybe the relay is bad as mentioned above.
Old May 28, 2011 | 04:34 PM
CPFR1924's Avatar
CPFR1924
yeah i did and they are new
Old May 28, 2011 | 04:36 PM
Edgethis's Avatar
Edgethis
Is everything else good on the truck? What about the fuel filter?
