Sound Off! Parts that SHOULD be reproduced!!!
#47
on
TIME will make reproducing these parts more economical. Give it 40 years and then repost the "new cab" request. Ford made them too well and sold way too many of them, good and bad problem to have. I think the 78-79 Bronco would be much more desirable to repop a body than a regular cab, give that thought another 20 years though.
#50
Is DC still saying that? Ridiculous. I agree with the lariat door panel inserts with the wood trim. We need these!
#51
#52
#53
Vinyl/woodgrain door panel inserts.
Factory air cleaners. Dont want my air filter open to the dirt/oil/water of the open engine compartment.
Updated and more effeciently designed ac compressors & ccot updates as well.
NEW Ford 2V Carburetors. The remans are now just shells of the originals.
Affordable, less than $30, dual tank valves.
Affordable, $120 say, remanned factory radios.
Affordable, $250 or less, tailgates. Who doesnt need a better tailgate?
Affordable, $ 75 or so, 73-77 standard & woodgrain hornbuttons. How many Dents need hornbuttons?
Opened up, Extrude Honed, factory manifolds. Okay, that is just a fetish of mine. I love faking out the locals with some trick parts and opening up the old FEs would help with fuel mileage too.
ABSOLUTELY NEEDED:
78-79 Factory Alloy Wheels & Accessories
78-79 Factory Push Bar
Affordable Fan Shrouds
Thanks to the guys for pointing out the repopped in-cab tank. Been looking for that for a while.
There, i'll stop for now...
ABSOLUTELY NEEDED:
#56
There is a headlight upgrade that helps the brightness of the lights. It doesn't matter if you swap in some fancy lights(aside from led) they won't be any brighter. The factory wiring puts a heavy load on the switch. The fix is to put a relay between lights and switch so the relays take the load. Do a search on this forum for "headlight upgrade" and you'll find how to do it with diagrams. It's super cheap too.
#57
#58
I know this, after all, I made the diagram on that thread . The lenses on my truck are very thick, and filter the light to the point it's hard to see brake lights in the daylight, and the design over-defuses the light on the tail lights especially. Plus I think done the right way, some aftermarket park, tail and side-marker lighting would look pretty good!
#60
how bout whole beds long & short bed I had a time finding a short bed for mine.
MADE IN USA parts instead of overseas junk.
drip rails
dashs with factory A/C & dealer options
crew cab headliner
crewcab rear doors
those overhear door straps in different colors
factory clutches & flywheels
more options on wheels
American Made wheel locks & lug nuts
drip rails
crew cab headliner
crewcab rear doors
