Power bucket seats
Old May 24, 2011 | 09:53 PM
Okiedokie's Avatar
Okiedokie
Power bucket seats
I found a deal on some seats to good to pass up. Size wise they will be good in my 53. When I built the truck I used a real nice 94 C---y pu seat, which my wife finds very uncomfortable. These seats are Lincoln Towncar, each electric. Unfortunatly only the wiring for the seats is there, nothing from the car harness. Also they have airbags on the side. Anyone have any knowledge about such seats, wiring diagram, and will the airbags be ok as long as no power to them?
Old May 24, 2011 | 10:03 PM
sdetweil's Avatar
sdetweil
Usually the airbag harness is a separate connector.
Then the seat wiring is 6 wire connections. 3pair. Like door window motors, they move one direction with power & ground, and the other way with ground & power.
Front /back, front up/down, rear up/down
Sam
Old May 25, 2011 | 06:56 AM
Okiedokie's Avatar
Okiedokie
Thanks Sam.
Old May 25, 2011 | 08:42 AM
hellfirejim's Avatar
hellfirejim
Sam,
Do you know anything about 95 cadillac CTS seats?? full power and heated? They are not pulled yet but I told them I want every nut and bolt, every wire relay and switch and anything else they see.
Also getting the 3 point seat belts.
jim
Old May 25, 2011 | 09:38 AM
tacson's Avatar
tacson
With my limited knowledge of seats working in a salvage yard part time I am going to say as long as the yellow wire isnt energized you should be good Okie dokie. I know most of your domestic have a yellow wire running to the seat for for airbagged equipped seats. About what year are the seats?
Old May 25, 2011 | 02:47 PM
Old F1's Avatar
Old F1
Last night when I read this I was going to send a note saying that I would not be comfortable sitting on a bomb that could go off at any time. Then realized that I was just tired and overreacting and anyway it’s not my ***! This morning I couldn’t care less but as the day grates on that subconscious little bugger will not shut up, just disconnecting the wire might be adequate for mortals but not for **** Virgo’s, I would take it out / off.
Originally Posted by sdetweil
Then the seat wiring is 6 wire connections. Sam
If anyone cares, my 3 motor (non-airbag) Cordoba power seats has a three wire terminal block per seat?
Old May 25, 2011 | 06:01 PM
Okiedokie's Avatar
Okiedokie
Thanks guys, Donald I don't know the year. If I can make these work, then eventually I will have them recovered and eliminate the air bags.
Old May 25, 2011 | 06:16 PM
tacson's Avatar
tacson
I would say 99 and up. I don't think any earlier than that had airbags.
Old May 25, 2011 | 08:10 PM
sdetweil's Avatar
sdetweil
Originally Posted by hellfirejim
Sam,
jim
Nothing specific. I would expect 3 connectors tho. Heat takes some power.
Sam
Old May 25, 2011 | 09:11 PM
52 Merc's Avatar
52 Merc
Just understand that electric seat motors and heaters draw a lot of juice, so make sure your electrical system is up to the task. Both from a wiring and an alternator standpoint. You don't want to fry anything or find yourself stranded with a low battery on some cold and dark night.
Old May 26, 2011 | 12:11 AM
hellfirejim
Since i am wiring them in myself any advice as to wire size????
The battery is new and the alt is a brand new reman of 65 amps. The only other thing that draws any power is the electric fan for the radiator.
jim
Old May 26, 2011 | 05:31 AM
sdetweil's Avatar
sdetweil
jim
my 'guess' is its a 12 or 10 gauge wire.. once you have the seat you can measure it. I think you would want to relay power this, with a momentary control switch, so if you forget to turn it off manually, it will be off when the truck is turned off.
Sam
Old May 26, 2011 | 06:50 AM
hellfirejim
Sam
Absoutely I agree with the relay deal. I am not to concerned about the pwr side of the seat as the switches are built in but I am concerned about how much the seat heaters pull. I have heard 30 to 50 amps.
Also my system is setup that when I turn off the ign it isolates the battery from the system.
jim
Old May 26, 2011 | 08:09 AM
sdetweil's Avatar
sdetweil
jim
a look at the manual (online) for the car, and see what the fuse is for the heated seats. (not so easy!).. I looked at my 08 Suburban and it says 'circuit breaker'.. (no size!).. my 08 F350 says 20 amps for the power draw.
Sam
Old May 26, 2011 | 12:06 PM
thepitshop's Avatar
thepitshop
jim
thats a pretty small altenator to run a fan, and all acessories, they ran those on chevettes!!
