Mpg jump
Old May 24, 2011 | 09:35 PM
cowman435's Avatar
cowman435
Mpg jump
After I put smaller tires on my truck I noticed a very small milage increase not much .5 mpg maybe but last week it jumped from 14 all the way to 18.5 mpg my driving habits havent changed the only thing different was I added some stp fuel treatment could that possibly be the reason. This is a 94 f150 300 i6 manual trans
Old May 24, 2011 | 09:41 PM
pintoches's Avatar
pintoches
The smaller tires Are just fooling the odometer!
Old May 24, 2011 | 09:43 PM
cowman435's Avatar
cowman435
Shoulda mentioned it had 35 went down to 31 and I am adjusting for the differnence in miles traveled Between stock and the 31
Old May 26, 2011 | 06:39 AM
TexasGuy001's Avatar
TexasGuy001
Is your PSOM programmed for 31s or the stock tire size?
I reprogrammed mine for 31s.
Old May 26, 2011 | 08:15 AM
cowman435's Avatar
cowman435
No it is not how would I do that?
Old May 26, 2011 | 02:37 PM
phoneman91's Avatar
phoneman91
Here is a good article:
HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles
Old May 26, 2011 | 03:27 PM
ChristopherN's Avatar
ChristopherN
How would I reprogram for tire size 275X60X15?
Old May 26, 2011 | 03:57 PM
rla2005's Avatar
rla2005
Revolutions Per Mile Calculator: Tire Calculator
Then do the math outlined in the previous link
Old May 26, 2011 | 03:59 PM
cowman435's Avatar
cowman435
Where would I find wiring diagrams to find circuit 567
Old May 26, 2011 | 04:18 PM
cowman435's Avatar
cowman435
Actually nevermind I figured it out.. Glad that was easy now I'll get a correct milage readings and the correct mpg thank you
Old May 26, 2011 | 04:21 PM
rla2005's Avatar
rla2005
The connector is located at the bottom of the instrumentpanel below the center of the glove box. On all vehicles, the dealer mode enable wire is Circuit #567 (LB/Y)
For reference it is Item #24 in the diagram below:
Courtesy of Steve83
Old May 26, 2011 | 04:25 PM
cowman435's Avatar
cowman435
Thank you very much!
17 Oaks
6.7L Power Stroke Diesel
13
Oct 5, 2015 11:13 PM
Amelio
27
Jan 28, 2015 12:54 AM
boats313
Apr 5, 2012 06:37 PM
sbaset
6.4L Power Stroke Diesel
Oct 16, 2008 03:35 PM
buggy
Mar 13, 2004 07:13 PM
