another degas problem????
Old May 24, 2011 | 09:21 PM
dan.alger's Avatar
dan.alger
My 04 runs great and has been doing this for a few weeks.....after shut off leaking coolant from degas bottle, thought it was a bad clamp and replaced..only leaks when truck is not running, I think there must be a crack in the plastic? Is there more pressure after you shut the truck down that would cause it only to leak after shut down?
Old May 24, 2011 | 09:26 PM
steelhead2's Avatar
steelhead2
Typically it'll heat up just a bit right after shutdown.you probably do have a crack in the bottle.have seen more than one post with cracked degas bottles.
Old May 24, 2011 | 10:59 PM
BLADE35's Avatar
BLADE35
mine cracked on the seam too
Old May 25, 2011 | 03:59 AM
wulfman's Avatar
wulfman
Mine is leaking almost same place time for new one.
