coolant change
Old May 24, 2011 | 04:28 PM
busdriver47's Avatar
busdriver47
coolant change
Getting ready to do a coolant change.I am going to the cat rated zerex.Was going to use Restore. A friend of mine works at the local I-H dealer he sayes they use Simple Green to cut the slime. What do you all think?
Old May 24, 2011 | 06:40 PM
bpounds's Avatar
bpounds
Simple Green is used if you have oil or fuel contamination. If you don't, it isn't going to do much for you.
Old May 24, 2011 | 10:26 PM
Dieselpop's Avatar
Dieselpop
I would use what the big boy use something that removes silicate gel
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
pop
