Powerbraking, can you spin your tires? I still CAN'T... Video with AE chart
#32
Yep, that would do it, but I've had it disconnected for years. I even cranked up the tension on the actuator arm, so 30psi is easily obtainable on the road. Keep it coming though, I need to figure this out.
#33
#34
I just watched your second video again and there is either something wrong with your boost gauge of there is something going on with your boost levels. Your boost pressure peaked up there quickly after 2000 RPM but falls to zero as soon as the RMP falls below 2k again. When you were cruising at around 1750 RPM the boost gauge was resting on the peg, even though you can still hear the turbo spooling. I guess I'm not that familiar with the 38R but can that really be the case? SHOULD that really be the case?
With the TC stall speed being around the 1700 - 1800 RPM range, you're not building boost until after the TC reaches stall speed. That would certainly limit your power braking abilities and your ability to jump said parking barrier.
#35
@63-65 mph, ~63 degrees F my EGT's were ~650-690 (Good), and boost was around 1.75-2.5 PSI. Could hear the turbo the whole time. Coming home, a little warmer, and the EGT's were about 25 degrees higher.
This means either the coating I put on the exhaust, or the renewed seal of the manifolds actually may have made a measurable difference in the EGT's. I'm hooking up the AE tomorrow, but if my oil is good, what next. Also, both mes the truck was fully up to operating temperature.
#36
So worked my A$$ off tearing apart the truck again this weekend, pulled the intake plenums, resealed them with FORD OE TA-31 (concrete in a tube), and put everything back together. So the big question... did fixing the boost leaks do the trick??? Well take a look...
<iframe src="http://www.youtube.com/embed/ZMBv5ITNWls?rel=0" allowfullscreen="" frameborder="0" height="349" width="560"></iframe>
EPIC FAIL! For some reason the change in injector pitch has my attention. I'm going to up the size of my custom lines from 3/16" to 5/16". I ordered 1/4" but was told for the PTFE SS braided line, it's always 1/16" smaller do to the reduced friction, and flows the same. We'll see. Just means I have to take all my CAC plumbing back off, and fight with those dang fittings on the rear of the engine while the turbo is perched on its pedestal. I'll keep going until it works.
#37
#38
Need someone smarter than I to help me out. I had the mechanical fuel gauge hooked up to the head, and it never dropped below 70psi. But this is suppose to be indicative to the volume. If my injectors were starving for fuel, wouldn't I see a drop in pressure at the head, even if the pressure at the filter was good due to the feed lines being to small? I don't know, just disgusted right now, sorry for the ramble.
#41
on
I don't know, but it sure is quiet now . Most of what I hear under the hood is the solenoids firing. Just am not sure I have a good enough flow to the injectors.
#42
#43
I also want to check my up pipes for leakage. I know I just R&R'd them TWICE!, but need to ensure they are tight. Problem now that they are painted with BBQ black, much harder to tell. My thought was cold engine, white paper about 3" wide, with slits cut in the paper about 2" deep and 1/4" wide, zip tied to the up pipe with the 1/4" wide strips pointing toward the collector. Then mount camera, illuminate, start, let idle for short period and give it some juice. Then inspect white paper for traces of soot/review video for movement of paper. I'll remove the fan for this test to reduce air movement in the engine compartment.
#44
What sorts of boost numbers are the rest of you seeing in the 17-1800 RPM range with your SD's? Anyone else running a 38R that could give us a baseline? Were you able to fry them when you first installed the 38R?
#45
If we are to believe the boost gauge, he isn't getting any boost, so I'm sure the MAP gauge isn't seeing any.
