2.5 in earlier Ranger??
Old May 23, 2011 | 06:25 PM
Iantiler's Avatar
Iantiler
IF what i've heard is correct a 2.5 is for the most part a bored 2.3..... any reason you can't replace a 2.3 with a 2.5?? I can pick up a '99 2.5 with low milage CHEAP. My 2.3 is doing fine at the time, just thinking on down the road.
Old May 23, 2011 | 08:45 PM
michigan66's Avatar
michigan66
The only problem I can envision is that the replacement 2.5 will need an ECM (computer) from the donor truck. There may be some equipment (emissions related) that is different.
Old May 23, 2011 | 08:59 PM
Iantiler's Avatar
Iantiler
Thanks for the reply, the donor truck is an automatic..... mine is a five speed so the ECM won't work. The engines LOOK the same.... I need to take a closer look.
