Hello All, just wanted to find out what you all are using to pull your egr. I've pulled mine out twice now to clean it, and its a pita to get mine out. I've read of folks tying some bailing/mechanics wire to the 2 screw holes, then wrapping that wire over a large pipe (for leverage) and then using the alternator to pivot the pipe on. Its still a pain. Hard enough to try an twist the egr to even get the wire in the holes. Does anyone have any tricks or special tools they use? I was thinking of buying a slide hammer. Thanks in advace.
I remove the 2 bolts, twist the valve so the bolt holes are open. Run each end of a heavy wire through holes and tie on. Then I have a loop in the wire I stick a piece of Re-bar through and use the alternator as a leverage point and pop up.
I use a length of rope/cord looped at both ends and a 2x2.
I unbolt EGR and twist it enough to get access to the ears. I then hook each end of the cord around the ears and then use the 2x2 as a lever against the top of the alt. to pop it out. Works like a charm. Similar to the bailing wire trick in the tech folder.
