Intake Removal and replace
Old May 23, 2011 | 07:42 AM
76F15OSuper's Avatar
76F15OSuper
When I was installing my Mechanical gauges I noticed that the back and front rubber seals of the intake where shot ( 400ci). So this past week end I decided to replace the intake gasket
what the valley pan looked like
I ended up spending hours cleaning up carbon out of the EGR valve.
My question is on the front part of the heads there is a port that looks like it is block with crud. Is this some thing that need to be cleaned out? or just the way it is. I tried a little but it seams solid.
And dose any body know what the torque rating is for the intake bolts?
Old May 23, 2011 | 09:18 AM
BiltFordTuff's Avatar
BiltFordTuff
as far as i know, intakes do not have a torque spec
Old May 23, 2011 | 10:03 AM
co425's Avatar
co425
Everything has a torque spec. Just use the spec for the smallest size bolt in your intake. Unless they are all the same. They need to be tightened in a pattern too.
Old May 23, 2011 | 10:30 AM
Death85e's Avatar
Death85e
Intake manifold torque spec as per Haynes manual is 5/16 bolts 17 to 25 Ft pounds and 3/8 bolts 28 to 32 Ft pounds.
Firewall
8---------7
2---------3
10-------11
12--------9
4---------1
6---------5
Radiator
76F15OSuper
30
Mar 16, 2015 10:28 AM
DHPRO
Ford Truck Parts for Sale
Apr 26, 2014 07:14 AM
76F15OSuper
23
Nov 19, 2013 08:04 AM
imabaka
48
Nov 5, 2013 09:33 PM
