Another wheel question
Old May 23, 2011 | 05:45 AM
iwanaflattie's Avatar
iwanaflattie
Hi guys!
As you know my truck is the "F1nkenstein" and I have the volare ifs with a chebbie rear end out of an 80's car.
The questions are:
1-Can I find steel rims for the volare with the right bolt pattern??
(I need 15"rims.)
2-Is is safe to redrill the steelies to match the rear(make my universal rims)
3-If I buy universal steelies will it be the right bolt pattern for both?????
thanks guys.
Old May 23, 2011 | 07:04 AM
sdetweil's Avatar
sdetweil
should be possible.. I got universal steelies on the 56 when I bought it.
5x4.5 on the front, and 5x5.5 on the rear. the fronts are the universals.
I don't know who made them tho.
sam
Old May 23, 2011 | 07:23 AM
iwanaflattie
Thank you Sam
Old May 23, 2011 | 08:30 AM
hellfirejim's Avatar
hellfirejim
I am not 100% cetain but I believe the mopar bolt pattern is the same as a ford. You should be able to find some universal rims with both bolt patterns...
jim
Old May 23, 2011 | 09:51 AM
52 Merc's Avatar
52 Merc
I would not recommend drilling holes to make your own universal rims. You could seriously compromise the strength of the wheels, plus, not having a proper seat for the new holes wouldn't allow them to mount correctly, creating a second safety hazard.
There are aftermarket "snow rims" sold by places like Les
Schwab that would have both bolt patterns like you're looking for. If you're patient and keep an eye on craigslist, a set may come up.
Old May 23, 2011 | 11:59 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you buy Steelies for a 5x4.75 or 5x4.5 bolt pattern, it will have both patterns...
Old Jun 13, 2011 | 04:11 AM
iwanaflattie
thanks guys.Vern do you know a good vendor for these steel rims?
Old Jun 13, 2011 | 06:06 AM
GreatNorthWoods
Check out New Page 4. That's Pete Paulsen.com. He's out your way too...
Old Jun 13, 2011 | 06:18 AM
iwanaflattie
Thank you.and you said either 5x4.75 or 5x4.5 will work on both? or if i buy a set of universals for a 5x4.75 AND 5x4.5 in a rim it will work on both patterns
Old Jun 13, 2011 | 09:43 AM
tinman52's Avatar
tinman52
Welder User
You may want to measure your bolt patterns to be sure....some bigger GM cars had 5 on 5 wheels....
Old Jun 13, 2011 | 11:59 AM
Moe Craig's Avatar
Moe Craig
Also your rear can be 5x115mm I would stop by your local tire store and ask to check your lug nut pattern... Check with them about if that is offered in dual bolt pattern... They can check with their surpliers. Find out a price you may be surprised... Either buy from them or start looking on line for some that you want... Also sometime if the dual bolt patterns are a lot more expensive, you can buy one as your spare and the other 4 single bolt pattern. just 2 cents worth!
5 on 4-1/2 (114.3 mm)
Plymouth - Volare '73-'80
5 on 115mm (4.527")
Buick - Century, Electra, LeSabre, Regal, Riviera (some) '83-'89
Cadillac - Allante, most others '84-'89
Chevrolet - Celebrity '85-'89
Oldsmobile - Regency, Ciera, Cutlass, Delta 88 '84-'89
Pontiac - 6000 '83-'89
- Bonneville, Grand Am '86-'89
5 on 4-3/4 (120.6 mm)
Buick - Regal, Century, Special (most mid-size) '64-'80's
Chevy van
Chevrolet - all (exc. as noted elsewhere) '49-'89
Corvette all
Corvair '65-'69 5-bolt
GM compact and midsize
Oldsmobile - 442, Cutlass, F-85, Toronado
(most mid-size) '60's-'80's
Pontiac - GTO, LeMans, Firebird, Grand Prix
(mid size) '64-'80's
5 on 5 (127 mm)
Buick LeSabre, Centurion, Riviera, Electra
Buick - Electra, LeSabre, Riviera, (most full-size) '35-'87
Cadillac - DeVille, Fleetwood '38-'89
- SeVille '77-'79
Chevrolet 3/4 ton vans
Chevrolet - Bel Air, Biscayne, Impala, Caprice, Kingswood '71-'76
- above w/HD package wagons '77-'89
- Blazer 2WD '71-'83
Oldsmobile - all full size RWD '40-'87
Pontiac - all full size RWD '40-'86
Old Jun 13, 2011 | 12:23 PM
old_dan's Avatar
old_dan
Here's a good link that describes how to measure bolt patterns....there is also some wheel information:
https://www.rsracing.com/tech-wheel.html
Also...look at the website for US Wheel. They make a lot of steel wheels & are priced pretty well. I went with their wheels because they had enough clearance for the disk brakes. I ended up ordering through Summit Racing.
Dan
Old Jun 13, 2011 | 10:11 PM
1oldtimer's Avatar
1oldtimer
you could also try :
rallyamerica
some people had problems with wheel vintiques been out of round, stockton wheel was super slow and expensive when they were around.
btw I wouldn't re-drill your wheels
