Rear Bumper?
Old May 22, 2011 | 07:04 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Rear Bumper?
I was going to remove the rear bumper to get it repainted, and was looking at
removing it. It looks like i have drop the fuel tank to get at the 4 bolt heads! Is this correct or is their an easier way to get the bumper off?
Old May 22, 2011 | 07:27 PM
housedad's Avatar
housedad
2 feet of extension on a 1/2 inch 20 inch breaker bar.
That does the trick. May need a wobble extension
and a really hard pull
I did it on this page:
https://www.ford-trucks.com/forums/9...cations-3.html
Old May 22, 2011 | 10:29 PM
Dubbs19s's Avatar
Dubbs19s
You can get it off with the tank up...used an impact on mine
Old May 23, 2011 | 07:38 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
It sounds like the hitch comes out with the bumper assembly?
Old May 23, 2011 | 09:12 PM
wpnaes's Avatar
wpnaes
They're separate. You can see the four clean holes in the frame in this picture. Need a long cheater bar to get 'em loose. Try not to mess up the bolt locks, else you'll have to really work.
Ford Truck Enthusiasts Forums - wpnaes's Album: Bumpers Install - Picture
Old May 24, 2011 | 09:00 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
thanks for the info! I was afraid if i tried to loosen those they would turn where
no wrench would fit! After the paint job, im going to extend the rear bumper so its not 1/2 under the rear doors!
shadows4
Aug 21, 2014 08:56 PM
aj197816134
Mar 6, 2011 10:10 AM
biederboat
1978 - 1996 Big Bronco
May 4, 2006 03:24 PM
