Ok, i replaced the thermo, still wistles and leaks around the cap when it gets warm, as far as i can tell the only place i see water is around the cap. and that is all the water i am loosing, as far as i can tell. Any thing else to check, sinsor, something little before i put it in the shop. Hopefully it aint a head gasket. 05 6.0. only mod is a superchip programmer. and it stays on high performance, but i dont push the truck. and if i have to put in shop, local dealer, what am i looking at price wise if its a head gasket.
thanks
walt
Well it sounds like HG i would do egr&oil cooler both ARP studs but use Ford HGs and that superchip did not help.
pop
and was going fishing in the morning. pulling a triton basss boat. you think it would hurt to pull it or not. then parking it until i can get it fixed.
20 ft bass boat about 10 miles to river and 10 miles back.
Walt the oil you see is not the oil cooler ,it is under the oil filter in engine valley. Also have you tried replacing the cap they do go bad , lot cheaper than trip to dealer for HGs
5k, dammmmmmmmmmmmmmmmmmmmmm. and yes i have tried a differant cap, ford cap, samd psi and temp. still leaking from cap. 5k, ill sell this truck before i spend 5k. or find a shad tree mech to do it.
