Loping, surging, dies HELP!!!!
Old May 21, 2011 | 05:35 PM
dj211's Avatar
dj211
1999 7.3 f250 having major problem. HELP!
started having problem about a month ago. started her up, let her warm up a good 15min, pulled out driveway and drove fine for about 15min. All the sudden i lost all power, truck was running but no power when i push the throttle, then she started to lope and surge. pulled over and waited 5min. then she was fine. drove for another 4 days.
then, samething. after about 15 of driving it did the same thing except the loping didnt stop. turned the truck off and then started the truck again. instantly started to lope.
went home and researched on the best website around...FTE!!!! came to the conclusion it was the injector wiring harness came loose. opened the valve cover and all was good. i did do the 25cent shim just since i was under the valve cover. that didnt fix the problem. then replaced the TPS and the peddle assmbly. still no fix. then tried replacing the IDM....still no fix!!!!
i do have a dfuser 10k tuner, disconnected it and still no fix. im to the end of my patience. anyone have any ideas of a fix? and help is very appreciated!!!!
Old May 21, 2011 | 05:48 PM
Visseroth's Avatar
Visseroth
have you tried changing the CPS as of yet?
Old May 21, 2011 | 05:57 PM
dj211's Avatar
dj211
that i have not. i talked to a mechanic over the phone and i asked about that. he said it would be a no start problem. mine starts fine, but then lopes and surges and if you push the throttle i have dead peddle for about 20seconds then the rpm's go up and if u dont feather the peddle back down to low rpm's it will die. do you think this is a CPS problem? however the CPS was the next thing im gonna try, what do i have to loose beside some green out of my wallet?
Old May 21, 2011 | 06:00 PM
Visseroth's Avatar
Visseroth
CPS can cause strange issues, not just a no start issue and you should always have a spare in the glove box anyhow just in case your truck starts acting up.
Start by changing your CPS. They are 25 bucks and you can get a grey one an the local dealer. Just keep in mind that the grey causes contribution failures in #3 and #8 cylinders which is fine, they work. When you can replace your CPS with a black one which you can get from Clay. They are just better CPS's but have a higher failure rate.
None the less always have a spare CPS and yes, change it out, that would be step 1.
Old May 21, 2011 | 06:07 PM
dj211's Avatar
dj211
"CPS can cause strange issues, not just a no start issue and you should always have a spare in the glove box anyhow just in case your truck starts acting up.
Start by changing your CPS. They are 25 bucks and you can get a grey one an the local dealer. Just keep in mind that the grey causes contribution failures in #3 and #8 cylinders which is fine, they work. When you can replace your CPS with a black one which you can get from Clay. They are just better CPS's but have a higher failure rate."
None the less always have a spare CPS and yes, change it out, that would be step 1."
ok, thank you very much for your imput! its kinda hard when im only 17 owning my first diesel but learning very quickly as i go! i did get a contribution code in cylinders #8 and #2. so i will try that next. thanks!
Old May 21, 2011 | 06:11 PM
Visseroth's Avatar
Visseroth
Well bud, welcome to the forums and you've already taken step 1 in learning more about your truck. You stick around here and these guys well make you a 7.3L diesel mechanic pro in no time.
2 years ago I knew nothing about diesels other than they didn't have spark plugs and ignited under compression, now I know enough to fix my own truck and troubleshoot these sweet rigs thanks to the great minds on this forum.
Stick around, read what others post and you'll be fixing other people's trucks in no time.
Old May 21, 2011 | 06:12 PM
Visseroth's Avatar
Visseroth
BTW, if the CPS doesn't work try unplugging your ICP so the PCM goes to default mode. This will elimanate the possibility that it is the ICP.
Old May 21, 2011 | 06:15 PM
dj211's Avatar
dj211
thanks for the encouragement! im definitely sticking around! hopefully this will be the fix. thanks!
Old May 21, 2011 | 06:17 PM
dj211's Avatar
dj211
do i start it while its unplugged? or do u unplug and plug back in?
Old May 21, 2011 | 06:24 PM
Visseroth's Avatar
Visseroth
The truck needs to be running with it unplugged, doesn't matter if you unplug it while it is running or before you start it. It may be best to unplug it before starting it
Old May 21, 2011 | 07:49 PM
dj211's Avatar
dj211
ok i just replaced the cps and that didnt work, but i did unplug the icp and that made it run like it should but the service engine light came on. where do i go from here?
Old May 21, 2011 | 08:17 PM
Visseroth's Avatar
Visseroth
Replace the icp then, sounds like the icp went out, it is about 180 from Ford or call clay and have him ship you one
Old May 21, 2011 | 08:30 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Riffraff Diesel: Motorcraft ICP Sensor
Old May 21, 2011 | 08:42 PM
dj211's Avatar
dj211
looks like im gonna be working extra hours this week thanks for all your help. ill post how things turn out when i replace it. thanks again!
Old May 22, 2011 | 03:02 PM
dj211's Avatar
dj211
replaced the icp and........ BINGO!!! the trucks lives again! thanks for all your help!
