Bronco II Ford Bronco II
Power stressing leak
Old May 20, 2011 | 09:41 PM
89broncoll's Avatar
89broncoll
Hey all I have a massive power steering leak on my 89 b2 I was wondering would I be better off rebuilding it or buying a new or used one?cab I use one off a ranger or explored or ford pick up?
Old May 22, 2011 | 11:24 AM
bigswede's Avatar
bigswede
Is it the hose or at the pump?
Old May 22, 2011 | 05:55 PM
89broncoll's Avatar
89broncoll
It looks like it's at the pump can't really tell haven't tore it apart yet
Old May 24, 2011 | 03:35 PM
fl1a's Avatar
fl1a
Check your hoses at the pump. the low pressure hose should be just a length of hose with clamps. Those will fail regularly when the rubber under the clamp breaks down. The other high pressure hose has fittings that come loose, but the more frequent failure is a wear through in the rubber portion. That will squirt fluid . the low pressure hose will usually just slop oil in the general area and appear like a pump problem. the low pressure hose is an easy fix.
