Ford expdeition 2003
Old May 20, 2011 | 07:37 PM
busymomof8's Avatar
busymomof8
yesterday our muffler started to make a loud noise, idling or driving, and the engine shakes and now the service check engline light came on and was blinking any ideas
Old May 21, 2011 | 02:12 AM
Moto Mel's Avatar
Moto Mel
You need to identify the noise. Is it a rattle or a hole in the muffler sound?
Old May 21, 2011 | 03:21 AM
alloro's Avatar
alloro
Originally Posted by busymomof8
the engine shakes and now the service check engine light came on and was blinking any ideas
It's a misfire problem. The flashing CEL is a warning that the misfire is sever enough to damage the catalytic converters if you continue to drive it.
Old May 21, 2011 | 06:31 AM
ScottyDsntKnow's Avatar
ScottyDsntKnow
Well first don't start it again unless you absolutely have to. Second is to to rent/borrow a code scanner if you don't have one and pull codes. Should tell you what is going on in this situation at least.
Old May 21, 2011 | 10:32 AM
busymomof8's Avatar
busymomof8
well it is making a loud noise sounds like a motorcycle could that make the engine shake??
busymomof8's Avatar
busymomof8
so how do I fix it
Old May 21, 2011 | 04:30 PM
Moto Mel's Avatar
Moto Mel
so how do I fix it
If it's the cats, all you can do is replace them. Get it scanned by a good shop or mechanic before you start throwing money at it. Remember, the advice and diagnostics you get on any forum is free and may not be Gospel. You get what you pay for, if you're lucky.
Old May 21, 2011 | 09:38 PM
alloro's Avatar
alloro
so how do I fix it
Your first step is to connect a code scanner and get the trouble codes. Knowing those will allow us to give you the best advice on what to check. We'll try and give you more than what you're paying for, despite what negative Nancy above me said!
Old May 21, 2011 | 09:39 PM
alloro's Avatar
alloro
Why would the cats be causing the misfire?
Old May 21, 2011 | 10:10 PM
ScottyDsntKnow
so how do I fix it
Again, scan the codes and find out what is wrong first.
Old May 21, 2011 | 10:28 PM
Moto Mel's Avatar
Moto Mel
Alloro, it seems that you are the only one mentioning a "misfire".
Old May 21, 2011 | 10:30 PM
alloro's Avatar
alloro
It's a misfire because his CEL is flashing. That's why the CEL flashes, to warn you of a sever misfire.
Old Jun 1, 2011 | 12:54 AM
eriklynden's Avatar
eriklynden
My truck blew a hose coming off the header it was just like what your describing
Old Jun 1, 2011 | 09:08 AM
ScottyDsntKnow
That would be the EGR hose. I'm hoping at this point he has done a thorough visual check and identified anything like that...
Old Jun 1, 2011 | 12:30 PM
Moto Mel's Avatar
Moto Mel
It would be nice to know what he found to be the problem.
