Dumb Question
Old May 20, 2011 | 07:22 PM
79F250Man's Avatar
79F250Man
Dumb Question
Hi all i have a dumb question, how many quarts of oil does the 400V8 take?? It hasnt had a change in a while so i thought i would change it and didnt know how much it took. Thanks,
Jonathan
Old May 20, 2011 | 07:59 PM
CalebJns's Avatar
CalebJns
Right about 6 qts with a filter change. If I remember correctly...
Old May 20, 2011 | 10:38 PM
VocaTexas's Avatar
VocaTexas
Almost all Ford gasoline pick-up engines take 6 quarts. There are a few rare exceptions. I've seen one that held 5 and several that held 7. Just add five, run the engine, check for leaks, then pull the dipstick and check the oil level if you aren't sure.
Old May 20, 2011 | 11:02 PM
The79Beast's Avatar
The79Beast
My 400 takes 9 quarts. Not only does my truck love gas, it also loves oil , PO added a bigger oil pan for cooling--or so he told me anyway.
Old May 20, 2011 | 11:11 PM
souker's Avatar
souker
Use the dipstick for measuring.. when the oil goes up tou the full line, guess what, you is full.. ayayayaya.. start at 5, and keep going till shes full
Old May 21, 2011 | 07:53 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
When I change oil I put almost one qt in the new filter before it goes on, and 5 down the valve cover. The left over amount from the filter will get added with the rest.
Old May 21, 2011 | 11:09 AM
79F250Man's Avatar
79F250Man
Alrighty then thanks!
