transmission reliability
Old May 20, 2011 | 05:07 PM
sinnedam's Avatar
sinnedam
I've always been leery of auto trannies to begin with but since u can't get an fx truck with a stick I had no choice..I have seen a lot of people on here with rebuilt trans and im wondering I can hope to get out of mine. So far at 77k miles she is doing great.
Old May 20, 2011 | 07:19 PM
shorebird's Avatar
shorebird
Have you changed your fluid yet?
Proper servicing is the key to long life of any machine.
Old May 20, 2011 | 07:39 PM
sinnedam's Avatar
sinnedam
Yes I have..just curious to hear others experience
Old May 20, 2011 | 09:41 PM
Coskid's Avatar
Coskid
It is a toss up some have issues and others go with no trouble at all. Mine is at 71k or something and I have had no problems. Just keep changing that fluid on a regular basis and you should be fine.
Old May 21, 2011 | 11:06 AM
cb_13's Avatar
cb_13
I have 110k and no issues. A friend of mine has a twin to my truck with 150k no issues as well. Nothing is for sure but without alot of heavy towing and with regular service 150-200k should be no problem.
Old May 22, 2011 | 09:26 AM
fordman19762003's Avatar
fordman19762003
I've never had a problem with Ford trannys, I change the fluid every 50k and they work just fine. My dad has 150k on his F150 and hasn't touched the tranny except to change the fluid and this truck sees alot of heavy towing.
Old May 23, 2011 | 03:04 PM
vpsr6's Avatar
vpsr6
When you guys change the fluid do you just drop the pan and re-fill and repeat to try and change all the fluid? I am not sure you can drain the converter to get a total change. Also what are you guys using for fluid?synthetic?
Old May 23, 2011 | 04:35 PM
aquaman's Avatar
aquaman
I open up the trans cooler lines and drop it into collection jug. Start and idle the engine 10-15seconds to pump the tranny dry before dropping the pan.
About 6-7qts get pumped out if I remember right. It spares the mess of fluid dripping all over the place as the pan comes off too. Once the pan is cleaned up, new filter put in, and reassembled, I fill it up with new fluid. Idle the engine for a few more seconds until what's left of the old fluid comes out and new fluid starts coming out. It all comes out pretty quick, so pay attention. Reconnect the cooler lines, top it off, and I've essentially done a complete flush. In all, if I remember right, 9-10qts of old comes out before the new stuff comes out. I think total capacity was 13 or something assuming it's dry filled.
I stick with Mercon5 spec'd in the manual. 67K on the rig now, last change was at 30K. No issues, and it's just about prime time to do it again
Old May 23, 2011 | 05:13 PM
shorebird's Avatar
shorebird
The first time I dropped the pan on my van to drain it .
I took advantage of having the pan off to drill a hole in the low point and installed a drain port.
Changed the filter with the fluid change.
My torque converter has a drain plug in it.
Anthony Giovino
General Diesel Discussion
May 27, 2016 09:04 AM
dbyrd342
May 24, 2016 01:37 PM
mixup
May 30, 2014 03:14 AM
skylinetowing
Dec 2, 2013 07:47 PM
