Sponsored by: Real Truck
Front end noise
Old May 20, 2011 | 02:44 PM
Batgeek's Avatar
Batgeek
Front end noise
Took a long drive today and on the way back home I noticed alot of noise coming from the front drivers side wheel. It sounded like a worn brake pad metal against metal combined with banging and clunking. It was mostly during braking. Got home and got the truck lifted. The pads were good but there was alot of up and down (12 o clock and 6 o clock) play in the wheel and very small amount of side to side play. The whole rotor assembly is moving inside the brake assemble causing it to bind. I'm sure that this was where the noise was coming from. The tire is also wearing strangely choppy and on the inside. What coul be causing this? I was hoping that someone could point me in the right direction.
Old May 20, 2011 | 05:09 PM
Batgeek's Avatar
Batgeek
Got the father inlaw over and found the problem. The lower ball joint is shot.
V8SHO
15
Jun 4, 2016 11:31 AM
Gevans17
Sep 14, 2013 10:48 AM
n2umr
2009 - 2014 F150
Mar 10, 2013 08:37 AM
Flawless_X
Dec 10, 2011 11:53 AM
MICHAEL34
Nov 26, 2010 06:48 PM
