HELPPPP! runs rough
Old May 20, 2011 | 11:27 AM
fordboyf150's Avatar
fordboyf150
HELPPPP! runs rough
i have an 88 f250 351w c6 trans. it recently begun running rough on me. i have checked the timing, its 10btc and the shorting bar is doing its job, map sensor is good, put a new o2 sensor in it, did a bg fuel injection cleaning, replaced spark plugs, wires, cap and rotor(all motorcraft) however it has long tube headers in it. the egr isnt hooked up it has a block off plate where the egr used to be at. it has a very small vacuum leak between the throttle body and upper intake. every once in a while once its warmed up it will idle alot better but not perfect. the o2 is only on one bank because it has no y pipe its true dual. has new fuel pump, pressure tests good. fuel regulator also tests good. but if i pull the vacuum line off the regulator it will run better. but not perfect once again. could this small vacuum leak be the cause of my whole problem? cus ive been leaning towards the pcm not pulsing the injectors correctly. any help is greatly appreciated
Thanks!
Old May 20, 2011 | 11:29 AM
ChristopherN's Avatar
ChristopherN
Have you changed the throttle position sensor?
Old May 20, 2011 | 11:35 AM
fordboyf150
that was actually one of the next things i was going to check. i just read about it in the chilton book.
Old May 20, 2011 | 11:36 AM
fordboyf150
and sometimes like at a stop light it will buck and jerk and almost stall. once you get driving though she doesnt lack any power at all
Old Jun 26, 2011 | 08:30 PM
ChristopherN
After I got my truck back from the trans shop, I had bucking and jerking while just cruising the highway at 60-70mph.
I'm thinking when that sensor goes, the problem was a little different but basically the same to each person.
Bob 79 supercab
Aug 7, 2015 10:33 PM
zstangkrewson
81
Sep 26, 2012 07:26 PM
zstangkrewson
Jul 23, 2012 12:25 AM
maniac2313
Aug 21, 2011 11:28 AM
bluestreak1979
1983 - 2012 Ranger & B-Series
Aug 21, 2006 08:48 PM
