need to lower egts
Old May 19, 2011 | 10:40 PM
tschauf's Avatar
tschauf
need to lower egts
I have a 95 that has stage 2s, modded 17 hpop, dominator 66 turbo,and a ts chip. I need to get my egts lower on hard pulls. Wondering what everyones take on water meth vs intercooler. Any advice would be appreciated.
Old May 19, 2011 | 11:00 PM
YoungFordAddict66's Avatar
YoungFordAddict66
Well they both lower egt's around 200 degrees, but the water/meth kit may be easier to install than an IC. Steve just added it to his truck and Glenn has had it for little while too. heres a link to steves thread https://www.ford-trucks.com/forums/1...-meth-kit.html
Old May 20, 2011 | 01:55 AM
Muktown's Avatar
Muktown
Id go with an intercooler before water meth
Old May 20, 2011 | 06:56 AM
427 fordman's Avatar
427 fordman
For sure an intercooler first, especially if you're towing with it
Old May 20, 2011 | 09:50 AM
JamesHajek's Avatar
JamesHajek
Intercooler first. It cools all the time...
Water/meth will only cool when you need it. Do the intercooler, then if you need more cooling, water meth is a good option...
Old May 20, 2011 | 12:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Agree with the IC first. Also maybe you want to reburn your chip to other programs that decreases the EGTs.
Old May 20, 2011 | 12:20 PM
Copper head's Avatar
Copper head
I put an all aluminum 99 model intercooler in my 97 F-250 Powerstroke and I couldn't be happier.
The install is a little involved, but not too bad. If you're sourcing the parts out used and not going with a "bolt-on" kit like Banks, your biggest obstacle is the cooler pipes. You'll either have to completely fab them out of 3" exhaust tubing, or find a set of fatory 99-03 pipes,.......but you'll have to cut, weld & modify those as well.
Old May 20, 2011 | 11:20 PM
rideracelivemx7's Avatar
rideracelivemx7
holy crap your running 2s with out an IC!? eff that! i just put in water meth to help my set up on hard pulls and works awesome. IC first then drugs
Old May 20, 2011 | 11:37 PM
oldbird1965's Avatar
oldbird1965
x2 on what Stevie said!
Old Sep 26, 2011 | 06:43 PM
PstrokeN's Avatar
PstrokeN
i would like you do the same on everyday driving, i have an inner cooler and i dont know if its my gauge thats messed up or what ill be doing 35mph in town and it sits at about 800egt on the inner state doing 70 with 5psi its almost at 1100)= my old 99 never got to 1100 unless i pushed it hard
Old Sep 26, 2011 | 07:50 PM
bad12jr's Avatar
bad12jr
Great use of the search!!!
My first problem I see is running the edge. I ran an Edge CTS I won for a week and absolutely hated it. Smokey with stock 90cc injectors and loud injectors. My egt's were high with no IC. My chip run much smoother and better.
The gauge could be bad or you have a boost leak. Is it the stock exhaust straight?
Old Sep 26, 2011 | 10:48 PM
rideracelivemx7
just realized i never put pictures up of the meth...if anyone wants them ill have no issue grabbing them!
Old Sep 26, 2011 | 11:05 PM
PstrokeN's Avatar
PstrokeN
even with stock
yes the exhaust is a 3in dp to the stock no cat or muffler, how can check for a boost leak?
Old Sep 27, 2011 | 05:47 AM
427 fordman
I'm always up for pics Steve. I'm hoping to set up a water injection system this winter.
Old Sep 28, 2011 | 07:12 PM
King7765's Avatar
King7765
Pictures are great! Gives me a visual on things I want to do in the future.
