2006 6.0 stumble
  #436
Old 01-25-2013, 09:57 PM
daddykitty's Avatar
daddykitty
daddykitty is offline
  #437
Old 01-26-2013, 06:14 AM
big dirty's Avatar
big dirty
big dirty is offline
Originally Posted by BLADE35
Glad we can Put this STUMBLE Thread to Bed Dave
Stay in Touch Bud
Oh I will buddy ........ I am sure there will be more questions from me LOL !!
and if I can help someone else out......... I would love to
  #438
Old 11-18-2013, 11:02 PM
diesoildad's Avatar
diesoildad
diesoildad is offline
Great...but long, thread! Amazing, your tenacity with Big Dirty!
Now that some time has passed since you chased off that stumble, was that indeed, the long term fix?
  #439
Old 11-18-2013, 11:29 PM
04badford's Avatar
04badford
04badford is online now
I seen this pop back up Dave I think we need to check on Benny Benny you OK Man
  #440
Old 08-14-2014, 04:12 PM
spikedog's Avatar
spikedog
spikedog is offline
Bump
Still running good? What a thread!
  #441
Old 12-15-2014, 01:26 PM
big dirty's Avatar
big dirty
spikedog .......... still "not" running good.
I mean it will still get up and go, but I still have the studder (or) bucking.
---- at idle in driveway ----
ECT = 186
EOT = 191
EBP = 16.8
was talking with Benny (aka:Blade) in pm's and I think I have replaced all of the sensors that would contribute to a bucking issue ........ all except the EBP sensor. I remember just cleaning the tube and the sensor and re-installing it.
the other night I was researching and came acorss a thread that mentioned the EBP and how it would contribute to a bucking issue.
https://www.ford-trucks.com/forums/3...must-read.html
I just purchased a new EBP sensor for $97 today. I took the 6.0 back home and pulled battery cables on both batteries and have the positive & negative cables tied together.
Drove the rock crawler back to work. When I get home I will replace it and if I have time I will take it for a test drive and report back the results.
David
  #442
Old 12-16-2014, 07:09 AM
big dirty's Avatar
big dirty
Replaced the EBP sensor yesterday......... and from what I have read..... the EBP & MAP need to be .5 (+/-) from each other. Something g is out of whack.<br/><br/>btw..... I am on the SCT performance tune <br/>
  #443
Old 12-16-2014, 01:52 PM
big dirty's Avatar
big dirty
This is at 55mph<br/><br/>With the SCT performance tune
  #444
Old 12-16-2014, 02:44 PM
pjerrn's Avatar
pjerrn
pjerrn is offline
have you put it back to stock? I would try to reload the stock tune run it for a bit and then reload the SCT tune. maybe it is not reading one of the sensors correctly.
  #445
Old 12-16-2014, 03:21 PM
big dirty's Avatar
big dirty
doing that right now ......
at lunch ........ cleared the KAM then I dumped the stock tune back on the truck
just disconnected the batteries and turned the headlights on........
getting ready to go out and hook everything back up and do the KOEO VGT relearn......... then take it for a spin.
  #446
Old 12-16-2014, 04:39 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Well, people are curious, 35,000+ hits on this thread! you are not alone!
  #447
Old 12-16-2014, 05:45 PM
big dirty's Avatar
big dirty
I know right ..... never expected that
Maybe I'm the gunie pig
Here is a question I have not been able to find an answer on:
EGR cooler Bypassed ...... Turned off EGR using SCT tuner ...
EGR plugged in ..... and left installed
if the EGR valve is bad will it still create issues?
  #448
Old 12-16-2014, 06:20 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
It might rabbit,it might
  #449
Old 12-16-2014, 06:56 PM
big dirty's Avatar
big dirty
sooooo 100% ........ absolutely
in the conditions stated above .......... if the EGR Valve is bad it could cause my bucking issue?
if it would I will buy another one
  #450
Old 12-16-2014, 08:06 PM
CPB1's Avatar
CPB1
CPB1 is offline
Well, that's a real good question and one that I have pondered in the past. While I really don't know for sure I would offer my thoughts.
The PCM determines how to fuel the engine based on EGR flow among other parameters. I don't know exactly how the tune "turns off" the EGR. I have always thought that the tune simple gives the PCM whatever it's looking for from the EGR valve. Now I am thinking that it's written into the program, or more specifically the EGR function is not written into the program.
I think you can determine this by looking at some of the EGR values on the SG2.
I also have a tune from an SCT tuner written by Innovative Diesel. I am gonna try and get some of the EGR values from the SG2 to see what they are.
Quick Reply: 2006 6.0 stumble
