Tailgate Strength
Old May 19, 2011 | 12:44 PM
flyinnuts's Avatar
flyinnuts
Tailgate Strength
So every couple of weeks I have to haul a 2k# round bale in the bed. Up to this point I have removing the tailgate (which I believe to much heavier than my 04 ) and doing the ole back up really fast and braking quickly to let the momentum roll the bale out of the bed and on to the ground. Kubota tractor doesnt have enough umphh to handle the bale with the front loader. I have to move it around with the 3 point spear.
My question is....what are the thoughts on leaving the tailgate on while performing this manuever? Will the cables hold? will the plastic inside liner hold up? Bad idea all the way around?
Old May 19, 2011 | 12:56 PM
Marauder92V's Avatar
Marauder92V
2k is a lot for those cables to hold. I couldn't find anything in the manual on weight limits. IMO I would remove it.
Old May 19, 2011 | 01:01 PM
EpicCowlick's Avatar
EpicCowlick
Two thousand pounds... hmmm....
There's probably some engineering specs around that would answer that. I remember reading something a while back about the man step being able to handle 700 lbs. If so, you're talking about a load focused onto two small points off center on at the farthest edge of the tailgate.
2,000 lbs equally distributed for a short period of time? The cables are probably up to the task, but I'd be more concerned about their attachment points to the tailgate and the truck bed.
Too many unknowns. Only way to know for sure is to roll one off and make sure you get it on video. You'll understand if I don't volunteer my truck for the experiment...
Old May 19, 2011 | 03:37 PM
ctownson's Avatar
ctownson
I often haul a pallet of feed, 50 bags of 50lbs each. When they load it in the truck, a lot of the weight rests on the tailgate at first until they push the pallet all the way into the bed. Never had a problem with it yet.
Old May 19, 2011 | 06:50 PM
maistroyoda's Avatar
maistroyoda
I would do more research first as it is an expensive part.
Old May 19, 2011 | 07:51 PM
marchare011's Avatar
marchare011
My son-in-law tried that back-up to unload technique with my 97 GMC a few years ago with rail road ties. Broke both cables, dented my tailgate when it hit the bumper, ripped the pretty shiny tailgate protector cap off the top of the tailgate. I had the hard plastic bed liner at the time so everything always slid around back there. The ties hung up on the protector, all the weight stayed on the extreme end of the gate. Way too much weight for too long. I think the hardest part was he had to fess up to what he did.
If you could put the hay in there so that it would actually roll out, I bet you wouldn't have much issue. I'm not sure I personally would employ that technique, tho. Let us know if you do.
Old May 19, 2011 | 08:00 PM
CornTruckDriver's Avatar
CornTruckDriver
Both my 02 and 04 350s had their tailgates bent by tossing a 40 lb square bale. now that is pathetic
Old May 19, 2011 | 11:30 PM
Jimax's Avatar
Jimax
350lbs. That's what's in the manual.
Old May 20, 2011 | 05:45 AM
ruschejj's Avatar
ruschejj
A couple of 8 foot long 4X4's running the length of the bed and out to the end of the tailgate should fix it.
Old May 20, 2011 | 06:41 AM
Tom's Avatar
Tom
...as long as they are secured to the front of the bed somehow. Otherwise they will do nothing for the last bale because there is nothing to hold the wood down.
Great idea, I don't think I would have thought of that!
Old May 20, 2011 | 06:53 AM
AzBlueWolf's Avatar
AzBlueWolf
they make a support for long loads that uses the trailer hitch...
if you took a sheet of plywood and pinned it to the support, the weight would be on that.
when finished unpin the plywood and slide it in, and the bar weighs a lot less than the tailgate.
I think something like this could be custom made to fit close to the tailgate...i would use 2x2 with 1/4 inch wall thickness for strength and 3/4 inch plywood.
Darby Extend-A-Truck Hitch Mounted Load Extender - Roof or Truck Bed Darby Hitch Cargo Carrier DTA944
Old May 20, 2011 | 07:19 AM
ruschejj's Avatar
ruschejj
If I did this twice/month I would def come up with something. Using something long in the bed while incorporating the hitch is a good idea. You can even make a slight slope to make the unload a little downhill.
Old May 20, 2011 | 07:32 AM
fz1dave's Avatar
fz1dave
Super Duty
No way I would chance it. The load extender is a great idea but at a capacity of 350# that doesn't seem to be an option.
I'd go without the tailgate. If you really want to find out if it will work though, I'd buy one from a junkyard for a test run.
Old May 20, 2011 | 07:45 AM
EpicCowlick
Regardless, we still need a video!
Old May 20, 2011 | 09:58 AM
buckmasters's Avatar
buckmasters
The sticker on my man step says 350 lbs. I'm guessing it's the same for the stripper pole as well (man, that could hold a BIG stripper).
