Charge Line
Old Mar 23, 2003 | 11:04 PM
cgartly's Avatar
cgartly
Charge Line
Hello, I am new to this list and have tried to find the answer to by searching through previous posts but have come up empty handed so far!
I just bought a used 2000 Ford F150 XLT 4X4 supercab, which I think has the factory tow package. Looks like the factory hitch and light plug.
My problem is that after probing the light plug for a constant +12V with the truck running I could not find one. I believe the bottom left (when staring into the plug) should be the charge line but there is no voltage present.
Is there a fuse or something that has to be added to make the charge line "active"?
One other question, I found the connector under the dash to the right of the steering column which I believe is for an electric brake controller.
Is there an adaptor cable that can be bought from Ford to be used to hook up a brake controller without cutting wires, or do different brake controller manufacturer's come with the proper plug already installed?
Thanks,
Chad
Old Mar 24, 2003 | 12:02 AM
MountainHound's Avatar
MountainHound
Post Charge Line
Superduties have a charge line in the hitch plug-in and it does require it's own fuse in the under-dash fuse block. Check your owner's manual for a map of the fuse block and open it to see if there's one in there. Alot of new trucks are shipped with no fuses installed for the battery charge line and the electric brake feed.
Looking into the plug on your truck, it should be the clip on the top-right (1 o'clock position). The bottom left is normally the ground clip. Hope you get it working.
If you're using a multitester to check for voltage, put the ground probe on the lower left and the hot probe on the top right and see if that gives you anything.
Old Mar 24, 2003 | 08:11 AM
Howdy's Avatar
Howdy
Charge Line
Your truck might have the controller connector. I believe it's a 4 pin, up under, to the right of the column. I think we bought our adapter from Ford for the '02.
Old Mar 25, 2003 | 11:25 AM
cgartly's Avatar
cgartly
Charge Line
Just wanted to post an update to let everyone know what I found.
Turns out the fuse in the dash fuse panel was there and good, the 30 Amp Maxi fuse was there and good under the hood, but the relay was missing!
Popped a relay in and it seems to work great now!
Thank-you all for the tip's and advise.
