Battery disconnect switch
Old May 18, 2011 | 11:23 PM
JT250's Avatar
JT250
My friends truck has a draw somewhere that we cannot track down. He would like to put a remote disconnect switch on it. How many continuous amp rating are required for our diesels? I am looking at a 250 amp and a 500 amp.
Old May 18, 2011 | 11:35 PM
snakedoc's Avatar
snakedoc
my batters are 1100 cc amps so i would think a 500 amp is not big enough. the gp are a dead short so they pull like mad.
Old May 19, 2011 | 08:04 AM
JT250's Avatar
JT250
Most batteries that I know of re rated higher thn 500 and ll of the switches that I found are 500 or less. I wonder how they rate them. They say they cn be used for gas diesel or even home (I'm guessing for. Solar battery)
Old May 19, 2011 | 08:25 AM
Kwikkordead's Avatar
Kwikkordead
Did you try disconnecting the alternator to see if the draw is there?
Pull fuses, relays, etc?
Old May 19, 2011 | 09:12 AM
JT250's Avatar
JT250
His vaccum pump runs off nd on when the key is off. I pulled a 30 or 40 am maxi fuse under the hood and the pump quit running. His remote start and alarm were also on that circuit so I unplugged it thinking it could be the culprit, but he said it still does it. He let's it sit for weeks at a time sometimes so thought the battery switch would be good for him.
Old May 19, 2011 | 10:20 AM
clintbonnie's Avatar
clintbonnie
My brother-n-laws e99 had battery draw down problems and it turned out to be the remote starter.. He discounted it and the problem never came back..
Old May 19, 2011 | 10:35 AM
JT250's Avatar
JT250
Yeah tried that but no luck
Old May 19, 2011 | 12:47 PM
clem1226's Avatar
clem1226
I have seen a few bad starters/starter solenoids cause a battery draw problem, Might be a place to look.
As for the battery disconnect, try finding the specs for a 7.3 ambulance battery disconnect, it should be somewhere on the net.....
Old May 19, 2011 | 01:03 PM
JT250's Avatar
JT250
Ambulance disconnect is a good idea thanks.
Old May 19, 2011 | 04:40 PM
gte718p's Avatar
gte718p
I just installed this one last week. 2000 amp current rating.
Blue Sea 9004e200 Battery Switch ON/OFF with AFD: 9004e200_Blue_Sea Genuinedealz
They also have good prices on wire, and lugs. I redid all my primary wiring, new battery terminals, and the disconnect for 150 dollars. That Inc users $20 for the crimper.
Old May 19, 2011 | 04:42 PM
gte718p's Avatar
gte718p
If you happen to be in a boating area west marine has a similar switch for about $60 buck. Don't buy wire from them though. It's good quality but 2-3 times more expensive then the Internet.
Old May 19, 2011 | 04:51 PM
JT250's Avatar
JT250
What I m looking at is a remote disconnect like a "battery brain" from summit racing or even something. Little less "fancy" from ebay. Bsically push a Button or switch in the cab that goes to a relay under the hood that disconnects it. So I don't hve to run hevy guge in the cab
Old May 20, 2011 | 04:29 PM
gte718p's Avatar
gte718p
I prefer the solid switch, but you could use something like
Cableform, Inc. - Mining & Tunneling Products - DC Contactors, Electromechanical
That actually may even be a bit small. Figure you have two 1200 cc amp batteries. In theory on a dead short you could see 2400 amps. In reality you. Will never see that many amps, but you also are not designing in a safety factor.
Be aware that big contactors are decent size draws. If you have a weak battery or charging system they can drop offline. That's bad as it cuts main power.
I build electric vehicles as a hobby. I'm forced to use contactors some times. I have had them drop out at inopportune times because voltage sagged momentarily. I'm not sure it's something I would want on a daily driver.
Old May 20, 2011 | 10:33 PM
lowbedriver's Avatar
lowbedriver
I use one on my e99,got it from Caterpillar and it works great!
Old May 21, 2011 | 01:32 AM
rockcrawler_101's Avatar
rockcrawler_101
I run a 200 amp continuous relay with a toggle switch into the cab. The trick is to cut the power after the starter. Thats where you get all your power draw. You should never see more then 200 amps running all your other stuff in your truck unless you have a large amp in the truck. That way i can turn the power on and off from in the cab.
