6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
High pressure fuel pump + rails replaced?
Old 05-18-2011, 09:45 PM
JerryHooper's Avatar
JerryHooper
JerryHooper is offline
OK.....we've had this 2008 F350 6.4L 4X4 Lariat DRW with 54K miles for 10 days. The other day we were cruising at about 63 mph pulling our 16K# 5th wheel. Without any warning the engine quit. It's now in the local Ford dealership and they are thinking it's a fuel pressure problem so they're going to remove the cab and check it out. Another friend says it's probably the high pressure fuel pump and fuel rails that are shot. I'm also told that the radiator leaks. From reading it appears that the radiator thing is fairly common. What about the other? Have many encountered the high pressure fuel pump problems? If so, how does this happen? Between the powertrain and ESP warranties I think (hope) I'm adequately covered. I'm looking for as much information as I can get. We traded out of a 2007 GMC Sierra 2500HD with which we had NO problems whatsoever.
Old 05-18-2011, 09:51 PM
Texas450's Avatar
Texas450
Texas450 is offline
My hpfp went out around 91000miles it was covered and I was out of work for 2 days....did your truck lock up or did it go into limp mode?
Old 05-18-2011, 10:11 PM
JerryHooper
Thanks for the post. I think it went into "limp mode."
Old 05-18-2011, 10:25 PM
Texas450's Avatar
Texas450
Texas450 is offline
Did the check engine light come on? If so do u know what code it was? Limp mode will limit the engine to like 50mph or something like that
Old 05-19-2011, 07:21 AM
senix's Avatar
senix
senix is online now
Received 1,428 Likes on 1,021 Posts
Fuel lines don't require replacment if it is the HPFP.
If it is an injector issue that is a different story.
If it went into limp mode maybe it is due to something else. Like a EGR/EGR cooler issue or maybe EGT sensors or something.
johnvirgil
30
12-07-2015 04:52 PM
mhofmann86
09-22-2015 03:45 AM
JW1971
1978 - 1996 Big Bronco
11-19-2014 11:09 PM
JW1971
11-12-2014 10:16 PM
GotThreeOfThem
07-10-2013 05:58 AM
Quick Reply: High pressure fuel pump + rails replaced?
