No roll .................
Old 05-19-2011, 08:57 PM
tritonman2001's Avatar
tritonman2001
tritonman2001 is offline
Jack up the rear end, with the front wheels chocked and the rear on jack stands, put it in drive gun it and let off and see if the rear wheels stop like the brakes are on. If they do then you have it narrowed down to the rear, and pull the rear calipers off and do it again to see what happens. If it still acts like the brakes are applied, then you have a problem with the differental.
Old 05-19-2011, 09:02 PM
bulla's Avatar
bulla
bulla is offline
Something has to be getting hot! These trucks don't just stop themselves! Did you jack it up and check for free spinning wheels? If it's free, try hitting the brakes a few times hard then try to see if any are hung up. When coasting down the road put your truck in neutral and see if it feels like it let's go. I have a feeling it will let you know what it is soon if you don't find it first! Good luck.
Old 05-19-2011, 10:15 PM
Vinford's Avatar
Vinford
Vinford is offline
Good idea ............
Old 05-19-2011, 10:16 PM
Vinford's Avatar
Vinford
Vinford is offline
Any transmission guys here?
Would the torque converter cause something like this?
Old 05-19-2011, 10:56 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
I know it may sound odd but I had this happen to another truck of mine. The brake booster went bad and somehow it was applying the brakes. I had to put my left foot under the brake pedal and pull up on it to get the truck home. It would do the same thing. The higher the RPMs the higher the vacuum, the more it braked.
Old 05-19-2011, 11:06 PM
VegasFordSD's Avatar
VegasFordSD
VegasFordSD is offline
^^ no vacuum on our psd's, they use a hydro boost system, not the conventional air.
I got nothing on this, I was thinking torque converter maybe too, but this is waayyyy outta my league.
Goodluck man, I hope you find it soon, you already know you came to the right place. The Genius powers will help you through this
Old 05-20-2011, 06:48 AM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is online now
Received 1,915 Likes on 1,155 Posts
I did this - ROTORS off - but did not put it in gear. It took a long screwdriver in the wheel studs to spin the axles, almost too hard to turn with bare hands.
I use IR thermometer all the time to check the health of things. You can tell a couple psi difference in trailer tires, easily evaluate wheel bearings and of course identify a sticking brake caliper. My rear diff runs 150-160* - same as my dually does and the axle bearings are usually just a little over ambient temp... I do feel like my MPG's aren't what they used to be, but since I don't measure the amount of fuel I put in my truck and I've been towing, blowing up turbos and such - its hard to tell. I had decided not to worry about it - but that strategy doesn't always work so good for me! Actually, at 254k, I'd like to do a rebuild and stiffen up the LSD anyway!!
Old 05-21-2011, 03:21 PM
Vinford's Avatar
Vinford
Vinford is offline
FIXED>>>>>>>>>>>>>>>>>>>>
Unplugged the wastegate and it goes just fine again.
Thanks for all the ideas.
Old 05-21-2011, 04:00 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Did you mean AIH?
Old 05-21-2011, 04:54 PM
Visseroth's Avatar
Visseroth
Visseroth is offline
wow, that is weird. Unplug the waistegate and it doesn't do it anymore? Sounds like something else is wrong in that area but I'm out of ideas.
Old 05-21-2011, 07:35 PM
bulla's Avatar
bulla
bulla is offline
I dont think any of us saw that coming!
Old 05-21-2011, 08:18 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
I could be wrong, but I bet he means the Exhaust backpressure valve....
  #28
Old 05-21-2011, 08:49 PM
Vinford's Avatar
Vinford
Vinford is offline
Anyone got a labeled picture?
The guy that told me to unplug it called it a wastegate.
Its a sensor with what looks like a vacum hose and a electric plug in.
  #29
Old 05-21-2011, 09:18 PM
Bonanza35's Avatar
Bonanza35
Thats what I meant, not AIH, sorry.
  #30
Old 05-22-2011, 08:59 PM
Vinford's Avatar
Vinford
Vinford is offline
So heres what i unplugged?
What are we going to call it?
Quick Reply: No roll .................
